rear wiper / washer not working
thholr
today my rear wiper and washer stopped working. When I turn the wiper on nothing happens. The rear spray doesn't work either. I tried taking another of the 15A fuse and replacing the one labeld RR WSH but that didnt do anything. Any ideas what to look for at this point ?
Roll the rear window down and then back up, and make sure it's all the way up.
How full is your resevoir? I always kept mine topped off and the first time it got low the rear quit working but the front works so I just added more and discovered it is by design just to give you warning when it's low.
Just a suggestion since it's a rarely noticed situation.
Excellent advice to simply roll the rear window down and then back up. I did this and everything worked fine. Thank you.
+1 This worked for me as well. I just got a certified preowned 2006 4Runner Sport and this had me FREAKED out.
Granted, I have a 12,000 / 1 year bumper to bumper. But still. I would have been JACKED.
Thanks for the advice!
Works great!
Just wanted to bring this back to the forefront... my daughter had this issue, no rear wiper or washer.
After checking the fuses (all OK...) I did the forum search and the simple solution arises!
Maybe next time I will search here first.... another reason why this is such a great forum...
Rear Wiper/Spray Problem Fixed!
Thanks drmorbius! Your advice to roll the rear window down then back up again fixed my rear wiper problem too! I guess that's a safety feature. The windows are supposed to automatically stop rolling up if something like your HEAD is stuck in there but I hope I never need to use that feature!
Window down, window up, problem gone. Aces! Now, how about making my lumbar support work. Maybe kick a tire, turn directional on and off or maybe swing a chicken over my head!? Gotta' love these trucks!
does anyone know why the down/up thing works? what is the ECU state prior to that? on my 2007, i can only imagine that its part of the "normalization" process after you replace a battery since that's the only thing that's happened recently to explain the rear washer/wiper not working.
thanks community for helping solve my problem as well
Had this exact problem the other day, and your answer quickly resolved my issue: was able to keep the snow off the back window on my way home. Thanks!
I know this is an old thread but you, sir, are a steely-eyed missile man.
Add me to the list of people you've helped with this quick and easy tip. Buying you a virtual beer...:cheers:
