Jtwo
Hello,
I usually don't post much because I use the "search" function but I'm in a bind and don't feel like combing thru the numerous threads.
Ok-
Installed a LED light bar + rear LED's, ran the power from the LED's to the engine and ran the grounds from the LED's to the GOBI bolt (where it bolts to the roof) see [MENTION=65614]Antman[/MENTION]s post.
Installed the Bussmann relay box, had three bundles of cable: one to the switches, one on the fused relay, one that is not fused and is constant hot.
Running AOB switches that have 4 wires, one hot, one ground, one for illumination, one for 12v keyed supply.
So I wired up the switches hot to hot on switch cable coming from the bussmann relay box, grounded the switch to good ground. Didn't wire in the other two because I need to figure out a good source for illumination to the switches.
Wired the LED's to the "Relayed" cables on the Bussmann. Ground the circuit using [MENTION=65614]Antman[/MENTION]s idea.
I am not getting anything, nada, nothing at all to the switches but when I hook either LED to the constant 12v source coming out of the Bussmann I can get the LEDS to power on.
I know I have good grounds as I have ohmed the circuit, only time I get 12v is going to the constant "HOT" from the Bussmann.
What am I doing wrong???
Ok-
