Replace Daytime Running Light DRL Bulbs
jfharlan1
I have an 03 4runner Sport. The daytime running light (amber bulb) above the passenger side headlight is out. The Toyota shop wanted $33 to replace it! I bought some bulbs at checker (3157NA/4157NA) that are supposed to work but I can't see how to get that bulb out. Do you have to remove the headlight assembly? Any help would be appreciated.
http://www.sylvania.com/ConsumerProducts/AutomotiveLighting/LampReplacementGuide/AutoLRG-Results.htm
above is a replacement guide for 2003 4Runner. As you can see that the Daytime Running Light(scroll down) is the same part no as the" Front turn signal" bulb and if you are refering to the small amber bulb in the headlight assembly, I think it is the front side marker bulb its 168.
A "LL" suffix stands for Long Life and it would mean less brightness since no bright bulb would last longer, (just my opinion):)
The little orange light bulb above the passengers' headlight is the "parklight". You need someone's baby hands to get in there. :snacker:
Dude, this thread is from 2009
"Information and knowledge expire.."
Sent from my Pixel 3a XL using Tapatalk
leolediola
