Flash Runner
Help with Squeak?
Alright, so I just got done replacing my alternator...... not a fun time, took about 5 hrs. I ended up having to take it out from the top after removing the air intake and fan/shroud. Everything seemed to go fine though, until the very end. Upon starting up my engine I had a loud and constant "squeak" at idle coming from the engine bay. :sad:
So I understand this might have nothing to do with the alternator specifically, but it happened when I finished this job.
Now a squeak I'm assuming would normally have something to do with the tensioner/idler pulley. However my original thought process is that the squeak was caused by the coolant that leaked out over the pulleys when I removed the radiator hose. So stupidly without thinking, I sprayed down the belt with WD-40. Squeak was gone and I thought nothing of it.
Then I went to o'reillys for my core charge, mentioned the squeak and the guy mentioned that WD-40 would eat up the belt.... so I went back and power washed out the engine bay hoping to clear off any WD-40.. alas the squeak came back right away.
Now the Squeak is on idle when startup, then seems to only squeak when I'm on the gas, and shortly after seems to go away entirely once the truck is warmed up. This makes me feel like it's not the tensioner/pulley since it goes away...
so any ideas on how to fix this squeak?
