Review: 4xInnovations Rear Bumper and Tire Carrier
Sorry fella's I've been out of town all day with the family and haven't be online. I logged about 250 miles of pavement pounding today in the 4Runner and I'm happy to say I have t noise, vibrations, rattles or really anything from the tire carrier. If it wasn't for seeing the top 1/3 of my spare when looking in the rear view I'd never know it's back there.
I'll try my best to answer everyone's questions below.
Thanks for posting, Ive been on the fence about purchasing this bumper for a while and every bit of info and pictures helps. I was curious about the gap (your diamond plate area) as I hadnt seen a pic with the hatch open yet, definitely needs something there to give it a more "finished" look.
How is the spare tire holder in terms of rattling or noise? Does it close up pretty solid? How about opening it, is it pretty easy, latch pins and hinges work smoothly?
I will say that the handle/latch design thingy (highly technical term) is a little quirky. It's hard to tell in the pics but it's a two part system. The big handle pivots on a bolt attached to the swing arm and locks into place when vertical. Then there is a spring pin that clicks in one of two pre-drilled holes in the handle as a safety to keep if from accidentally releasing. Once it's closed and the spring pin in it holds like a tank but the release pin tends to get stuck and takes bit of force to pull it loose.
I do think that mine in particular is tight due to excess paint in the pre-drilled holes from the body shop.
On the other end of the swing arm is another spring pin that rides on a nice stainless steel skid pad that will lock the carrier open in 2 different positions.
I'll try to snap more pics of the latch system.
Did you paint or powder coat? Did you do it or pay some one? Is it factory match paint or as close as you could fine?
Do you see a reason they don't match the finder line with the flare and the end of the bumper? More tire room? Would line up with the flare off?
I had both the front and rear bumpers painted the factory 181 silver paint code from my '99. Both are base coat/clear coat, same as body shop would do.
I "think" the end caps are slightly shorter to accommodate larger tires. Doesn't bother me near as much as the width of the ARB front bumper against the overly large limited fender flares. ;):
Nice touch on the diamond plating. I just got mine yesterday and that thing is built like a tank. Did you powder coat the backing nut stick on the mount also?
No, I just primed and painted those with rattle can while the bumper was at the shop.
I also wanted to know if they built in wiring for lighting the license plate up??Russel
4xInnovations sends a nice set of LED Light Bolts with the rear bumper kits as well as the plate mount and all necessary hardware. I haven't finished wiring up the plate lights yet but it should be pretty straight forward.
Nice setup, on a side note. How do you like the BF Goodrich AT's so far? I think that's the next set of tires I want. Did you go with the 265 70r 16? Thanks in advance.
I love the BFG ATs for what I use this rig for. I used to be into hardcore crawling where the ATs were not a good fit but with this rig it's primary purpose is family adventures and mild off roading so the ATs are a great fit. Contrary to what most say on here I'm running the "E" rated 265/75r16s with Old Man Emu suspension. With the extra weight of the bumpers and gear I have no complaints with the "E" rated BFGs.
Looks great. Exactly what I was looking for. Would love to see some side shots so we can view how far out the tire goes. I hang a dirt bike off th back and need the clearance.
Here's a decent pic of how far the tire hangs off the back. Tire size is 265/75 on OEM 5 Star wheel. The actual tire carrier gate is snugged up very close to the tail gate, within an 1" or less. Very nice, snug fit.
Excellent job with the install and paint work on the bumper, very clean setup. Thanks for the detailed mounting pics. Any idea of weight of the bumper?
Love your rig! :rockon: I posted on your thread several weeks ago when you first put the bumper on. What tire size and suspension set up do you have?
Yes i remember your post. I have the Sonoran Steel 1.2 lift with OME 861s in the rear. The 1.2 rear coils were not tall enough for all my gear and rear bumper so i sold them and got the 861s cause i like the rake. Tires are 285/75/16 Hankook Dynapro MTs.:thumb:
The bumper is set back from the flares to accommodate 35's without cutting.
Glad to know that the frame on my 4Runner worked as a nice template for everybody else :fro:
[MENTION=79813]E-LOK'D[/MENTION] and [MENTION=114619]cbr900boy[/MENTION]. Installation of the rear bumper - How did you guys take off that welded 2 hole bracket inside the frame rails? I think I'm going to sawzall and hammer chisel it out. I saw on the other thread torching it out might be a little to much.
I never touched thoses brackets. As a matter of fact you still use them to mount the bumper. What i did with the 4x innovations bracket is i pushed it forward passed the factory welded ones. You just have to line up the holes and you're in business. So in total i used 8 bolts even though you have the option to use 10. Hope this makes sense.
Actually I left those 2 welded nuts in place on both sides and just used re-used the 4 17mm bolts that were there from the factory. I cut the nut strip in half and slid the back two in with a magnet on each side. I drilled the extra holes on the very end of the frame rails so I have 5 bolts on each side. :bigok:
Thanks [MENTION=79813]E-LOK'D[/MENTION] and [MENTION=114619]cbr900boy[/MENTION]. I took the sawzall and the hammer to the brackets. Took about an hour to remove and prep/paint. Will install the bumper today with the whole nut strip.
Has anyone ever done a comparison between this and the Shrockworks? Can you get the 4xInnovations bumper already powder coated? Not trying to hijack the thread, just wondered if anyone knew. I am in the market for armor soon.
Good stuff! Post some pics when yours in on. :hatsoff:
[MENTION=79813]E-LOK'D[/MENTION] and [MENTION=114619]cbr900boy[/MENTION]. Here's mine guys, I have it in black powder coat.
Your guys' bumpers are looking great. I love that you all are moving away from the standard black and doing the color match! Thanks for sharing.
Alas, unless policy has changed, they don't have alterations for those with body lifts.
Looks really nice E-LOK'D.
We do have 1 and 2 inch body lift options available now for both the front and rears.
Yep, like Connor said, bigger tire. If I remember right a 35 will fit without trimming the bumper. I think that's what Connor is running. We did line it up with the natural line of the fender flair so it is at least not a random spot out in space.
I have the same questions as Okiyota has? Also...is it difficult to open and close the tire carrier?
Thanks for the write up!! Great job! I wish other guys with different rear bumpers would do the same! Hint, hint...lol!!!
Thanks again...
-Russel
It does take two hands to operate the latch, which is admittedly a bit of a draw back. However I felt it was necessary to have the stronger locking feature over the other hook and loop style latches. I've heard of too many times of those coming unlatched. We had our fair share of issues in the beginning too but that's all been worked out now.
No you can't, they don't offer powder coating. Had mine powder coated locally.
We do offer powder coating now. We finally have a local supplier that has a really nice powder line. The trouble is that it is a whole lot less expensive to ship these bare steel then it is painted, and it is nearly impossible for us to color match. To powder coat, they must ship freight in a custom built crate. If you're willing to find a local powder coat shop to do the job you'll save a fairly chunk of money. We do have prints available for powder coaters to use to quote the job, just send me an email and I'll send them to you.
On the flip side of that, we are VERY picky with the powder work, and our supplier knows what we're looking for; the same you are looking for, a quality paint job!
tyler_ross
