Review: 4xInnovations Rear Bumper and Tire Carrier
For the light buckets we offer the 4x3 rectangle tube (2.75H x 3.75W inside dimensions) for standard mount small driving lights or the flush mount cutouts for the Rigid SR-M flush mount leds. That I know of the SR-M is the only light that fits with that flush mount cutout pattern. If you have a specific flush mount light you want for whatever reason please email me and I'll see if we can do that for you.
I'll also say that 4xInnovations [MENTION=76968]traxman25[/MENTION] has some of the best customer service of any business I've ever dealt with. Him and Steve at Sonoran Steel both have a customer for life in me. :trophy:
[MENTION=76968]traxman25[/MENTION] cuts his bumpers to fit Rigid SR-M flush mount lights (or the non-flush version of those). If you go to Rigid's website there is a template that I printed out to get measurements from in order to find some lights with the right mounting dimensions. I ended up going for the el cheapo MICTUNING flush mount lights from Amazon since I thought paying $200 for lights seemed a little ridiculous (and I'm cheap too, mostly it's because I'm cheap). These are almost the same dimensions as far as mounting as the Rigids, but not quite. I ended up cutting the little tab between one of the mounting screw holes and the light cut-out hole on each side with a dremel and they fit in perfectly tight and without showing any of the mounting holes at all (as you can see in my pictures).
I had this bumper painted locally and asked them basically to rattle can it with Rustoleum bedliner so I can touch up any scratches easily myself. Would have done it myself like I did their front winch bumper, but I didn't have a space to be able to do that. It didn't affect the mounting of the MICTUNING flush mount lights at all.
Thanks weekendclimber! I appreciate the details on the bumper modification and lights. I'm in the same camp as you....I'm not going to be spending a ridiculous amount of $$ for the led b/u lights.
I don't live in a great neighborhood. I call it Warzone Kent, WA. I have padlocks on the Jerry can holder as well as running a thick cable lock through my spare around arm body, and jerry can itself.
Once I get my RMR roof rack, i think i might start putting my Hi-Lift on the rack and maybe move the jerry can as well. I keep dragging the license plate on transitions that have steep departure angles. This would also decrease the amount of weight beyond the rear axle.
I went to highschool at KM and my mother still lives in Kent. Know the "warzone" well, lol.
Yeah got mine a week or so ago, just no time to get anything done yet.
About all I have to do is put the 4Runner in between them and I'm good to go...
Good luck on the install!! I did the front all on my own, which was a PITA. It helped using ratchet straps over the trusses in the ceiling of the garage since it weighs about 250 lbs with the winch in it.
Also, one thing on the rear that I did differently and might be a solution that [MENTION=5345]habanero[/MENTION] points out earlier in the thread. I ditched the included LED bolts for the license plate lights and went with this light off Amazon. This will allow me to remove the license plate in the future without having to snip wires. For $10 it was an easy decision.
Gonna look so good!
Different style, same idea. Weekendclimber's is more slim...
LED Trailer License Plate Lights w/Bracket (SAE/DOT Certified), waterproof, heavy duty by Online LED Store.
which was nice when I changed the broken blue frame for a different one- and will be nice again when I get the new plates Missouri is issuing as the old plates come due.
To install my bumpers I used my cheapo scissor-style harbor freight tranny jack. I may have also aired down the tires to bring the truck down a little, it's been awhile.
I looked at those as well but couldn't find one in black like that with delivery in the window I had to get it installed. I'm going to be hunting the Pick-n-Pull soon to see if I can find one of the older Hilux style surrounds that has "Toyota" emblazened on it. Saw that on another's build thread somewhere.
Yeah, hadn't thought the LED plate lights through yet, but glad you did. They would be fine if they threaded from the front, but with the nut in the back you do have to disconnect wiring.
I'm assuming because I went with the dual can carrier, my plate will be up in the tire itself, if you look at my swing out closely, you can see they extended the 2" tube out and then provided a plate carrier that slips over that extension. So, in any case mine will have to disconnect. If/when the plate changes though, I don't want to have to cut the wiring so I'll look into the lights you guys found. Probably add a rear cam while I'm at it, my cheap android headunit has the input for it so might as well use it.
going to the powder coater today...
Yeah, the one that habanero has is on my list of soon to be mods. Unless, I can find one like this first. weekendclimber, I think this might be what you are talking about. It was in the "Official 3rd gen 4Runners on 35's Pic Thread" It is actually the stock 2nd gen swing out license / light unit thingy.
Also.. For those of you thinking about throwing on some big 35" tires...
Side note. As far as fitting large tires with this bumper. The 315/75/16 fits just fine on the rear swing out.
But,
During suspension articulation a 315/75/16 (or 35") tire will contact the rear bumper at the outboard leading edge of the wing on the wheel well side. *hope that makes sense* It's not too extreme, but it does contact.
I just got some longer bumpstops, 4.5" Daystar Comp bumpstops to see if that keeps me out of the top of the wheel wells with my 3.5" backspace SCS F5s. I am trying to keep from having to hack the rear wheel wells up that much. They will be replacing my Daystars that came with my SS 1.2 rear only lift.
That's exactly what I'm talking about!
Camelback has them listed for $40, but I doubt they have them in stock. P/N: 75102-89119
I doubt they'll have since it was discontinued quite some time ago. If they do have one keep in mind that's just the bracket. That does not include the Toyota bezel, and I don't think the lights either.
Mike
What are we looking for, 2nd gen swingouts? I used to see them in the pick and pull yards here in SLC but I haven't even been in a yard in years and I don't have time to go digging, sorry.
We're actually looking for the license plate light/surround from the 2nd gen swingouts. Sounds like they're a rarity now.
20160116_181338_zpsnjwdoo5c.jpg~original
This just fits about all of my wants in a rear bumper, especially the folding table. Hoping to place my order in the next few weeks and get this 4runner into its summer bod!
