Rokblokz Mudflaps, good cold day project.
zonzin
Member
Too cold outside today to do much but heat up the garage and take care of a couple mods. Installed heavy duty rear hatch shocks, installed light sensor to auto adjust instrument brightness, and the best mod, installed a set of Rokblokz mudflaps. OEM flaps were just to narrow and did not do a very good job of , flappin'.
The installation of all items was straight forward and easy. The mudflaps are well made, great fitment, and easy to install. Pretty happy with them and at 149$ a good, inexpensive mod.
https://www.toyota-4runner.org/redi...m/products/toyota-4runner-mud-flaps-2011-2018
The goods:
Before:
After:
nice my XL are getting delivered monday?
running wider fender flares
and will have the 17x9 -38mm offset ray10s monday also.
hope this works ok with my aftermarket rear bumper.
I just installed these as well last month. It's tough to tell in this photo, but the regulars work well with 285s. There's a big difference in terms of spray on the side. I'm not sure there's a difference compared to the OEMs in terms of hatch spray.
They do hang lower than the OEMs enough that I'll probably take them off when it's time to hit the trails in the summer.
Also - zero rub with the 285s, which is what drew me to them in the first place (OEM fronts were removed with the lift/new wheels).
did all the holes line up on your rockblokz? for my front , the bottom hole is off by a inch or 2, but i dont know if something was previously removed on mine. i have aftermarket flares and bmc done, so i'm not sure if something was removed that might have shifted the hole.
Thanks for the pics, exactly what I was looking for!
It seems stupid, but I'm fighting with my front mudflaps since adding Spidertrax 1.25" wheel spacers, running 17" FJ Cruiser 8-spokes with 255/75/17 Duratracs. Was able to move the front fender liners ahead and out of the way, but even with the inner mudflap panels completely removed I'm still getting rubbing in reverse with the wheel turned...so every time you back out of the driveway or a parking spot, very annoying.
i took mine off. reverse it was definitely rubbing
275/70r17 on scs 17x8 ray10s
Have you replaced your UCA's? What is your caster at? If you have it between 3.5 and 4 you should have no rubbing.
Stock UCA's as I've only got a 1" leveling spacer on the front, I had it aligned after installing the spacer lift but I'm not sure what the castor setting was.
You may want to take it back and have them re-align for at least 3.5 cater , both sides. Iffy weather or not you can get that with stock UCA's.
Crookedcat
