Safelite Windshield Chip ... ahem ... repair?
Okay folks, guess I've lived a charmed life and never had to deal with a stone chip repair on my windshield and need your expertise and feedback.
I got one on a trip back from Michigan and called my insurance company to see if they covered it. They waived the deductible and made the appointment for me at the local Safelite. The chip was very small (about size of dime). This was the end result?
I always thought the proper way to repair the chip was to drill out the hole to clear out the cracked facets and then fill with resin.
I argued with the manager and three technicians at the store and they said all they do is "smooth" out the chip with resin to make it structurally sound and that they do not ever drill the hole out. Of course they said they could replace the whole windshield if I wasn't satisfied, but I'd have to pay my deductible.
To me, it looks no better than the original chip and even a little worse because of the resin rings. The large circle and some of the lines leading out from the center are actually just resin and not part of the small original chip.
Should I complain to my insurance company or is this a normal repair?
Thanks in advance!
I'm amazed they even tried to repair that
You don't have to drill the hole but you're right that they should have smoothed it out. The goal is 1) to remove any loose metal debris that will remain visible and 2) smooth edges so you will not just have new crack start at one of the edges. I always use a small metal pick then an emory cloth.
One tip that helps (not 100% prevents) is watching your distance when behind another vehicle, especially at higher speeds.
Update
Replaced yesterday with OEM glass.
They did scratch the paint along the inside edge of the A pillar while removing the old glass...
It is not visable unless you are looking for a windshield replacement scratch.
Just going to touch it up myself to avoid any rust issues, hoping I don't need new glass again anytime soon.
They did manage to get the heated windshield hooked up properly which I imagined was another possible ball they could drop.
I will check with the dealer next time and see which vendor they use for glass repair.
