Scan Gauge II Codes..New stuff
For 285/75/16 tires there is a 7.3% difference from the stock size of 265/70/16. The ScanguageII lets you set a 7.0% difference which is close.
I just remembered, I checked on this the other day and this is also (at least partially) incorrect.
My SG2 allows me to enter a correction factor of +/- AT LEAST 18%. I was driving around and remembered this thread, so at a stoplight I got into the menus and checked and sure enough, I was able to adjust it by 18% before the light turned green. I'm not sure how far it will actually go beyond that, I'll bet it goes to at least 20%, and that should cover 99% of the mods people are going to do to their 4Runners.
Maybe you guys are running some older software on your SG2's??? I know for sure there are different software versions.
I can't get any of the X-Gauges to work. I have tried every code that Scangauge has on their site (ISO) and every combination that everyone here has posted. I'm trying to get A/F to work (yes I tried all 17 codes + the ones posted here). It would also be nice to get Barometric pressure and Altitude.
Does anyone have a 2000 or older rig with the A/F working?
Maybe it's the O2 sensors that I have in it.
Please help!
Please help!
A/F has never worked for me on my '99. I haven't tried it on my '01. The Altitude and Barometric pressure will never work, because the vehicle's OBDII doesn't have sensors for them. From what I understand anyway.
It looks like the 96-2000 uses different O2 sensors than the 2001-2002.
To get the A/F to work, the O2 sensor must be a wide band. The 2001-2002 must have wide band O2s.
Scangauge did get back to me (they were very helpful) I ran some commands and the codes that came back confirmed that the older 4runners don't have what is needed to get A/F ratios.
'99 and '00 Cali. emissions trucks and all '01-'02 have wideband front O2 sensors.
I got two versions of the A/F code to work on my 2001 yesterday. However, I don't get a decimal point in mine. Not that it's a big deal...but I thought someone DID get a display like this >> 14.65....opposed to this >> 1465
If anyone has ever seen A/F displayed with the decimal point, please chime in.
While trying to figure out my issue with, tech answered your question.
"The one listed on the forum (used by ALBPM) is just slightly different than the very first A/F code that’s listed on our webpage in the ISO section. You’ll notice that all the digits are the same except one:
ALBPM’s A/F
TXD: 686AF10124
RXF: 04410524
RXD: 2808
MTH: 05B900800000
From the ScanGauge Website
TXD: 686AF10124
RXF: 04414525
RXD: 2808
MTH: 05B900800000
NAM: A/F
The only difference is there’s a 4 in the 5th digit of the RXF in the ScanGauge website code while ALBPM’s has a 0 in that spot. This is actually why ALBPM’s A/F shows values like 1470 instead of 14.7 – the 4 in the RXF that we use inserts the decimal correctly."
Thats why. Thanks gerdo
You'd think. But I tried both. And they both give me the same thing....no decimal point on either one.
Maybe I entered it wrong. I'll double check later.
Ok, so I didn't complete the "process" when I edited the code. If you have an already existing X-gauge, and you edit it, not only do you have to "save" in the edit menu, but then on the main gauge screen you have to re-select that gauge by cycling through them all.
I now have an A/F that reads 14.6. Love it.
This is the code I used:
TXD: 686AF10124
RXF: 04414524
RXD: 2808
MTH: 05B900800000
NAM: A/F
TXD: 686AF10124
RXF: 04414524
RXD: 2808
MTH: 05B900800000
NAM: A/F
I'm going to have to try the cycle thru thing. MAYBE it'll work on mine. I doubt it.
Just got a Scan Gauge II and put it in today. Not sure if the A/F is working correctly but I got numbers on the screen. I have a 99 SR5 and this is the code I used :
TXD : 686AF101B4
RXF : 044145B40000 ( use 0 in the 5th place if you don't want a decimal like 1479 instead of 14.7 )
RXD : 2808
MTH : 05BE00800000 ( alternately you could use 05B900800000 )
Now the question is, is the ambient air temp sensor only installed on the Limited or all they installed on all models and just not hooked up ? I read a post where someone got the Air Temp code to work but they didn't list the code or type of 4runner they had. I used this code and it doesn't work for me :
TXD: 686AF10146
RXF : 004415460000
RXD : 2808
MTH : 00090005FFD8
TXD : 686AF101B4
RXD : 2808
TXD: 686AF10146
RXF : 004415460000
RXD : 2808
MTH : 00090005FFD8
I just came in using this a/f code and actually got something to work but it reads aprox 1/2 of what is should be. My gauge is reading like 7.57.
Looks like I'm half way there lol. Thanks naloboy!
shayne
Like I said I'm not sure if my numbers are right, I was getting 9.5 sitting in my driveway. Ran to the store about 6 blocks away and went up to 12.7. I have a long drive to work tomorrow so I'll keep an eye on the numbers and give an update
Gonzaga Lobos
