ScanGauge 2 Codes?
So ive looking on there website and im trying to figure out these codes to input. I see the trans temp codes but im not seeing the codes for other things like coolant etc. I know ive seen some people on here with these much help is appreciated on getting these codes cause all i see is stuff for Prius
Water temp is already in it, as is air temp and some others.
Just the trans temp needs the x-gauge code input.
The 2003-2004 Use the older ISO code (like 3rd gen T4R) instead of the newer CANSF code such as yours. FYI
Awesome i see you can also add othe r guages to with the obd2 cansf gauges it can tell anyhitng from ambient air temps to hp to cat temps
Crookedcat
