Scion HU + Infinity Kappa?
JohnOB1
Hey, its me again trying to decide on a system. I read all of the replies and thanks for the help and info. I was curious if just the Scion HU and Infinity Kappas would work without an additional amp? Would it be worth it?
It'll work, but Kappa's are very power hungry.. Another amp would be best..
Why didn't you just add this question to your existing thread? It's still fairly recent and active..
My friend had Infinity Perfects on his built-in amp and they sounded great, an external amp would be best, but it sounds fine without too.
I'm looking at the 6x9 kappas. What is the difference between the 2 way and 3 way? (I think that the 6.5's are all 2 way).
Also, if I were to get an amplifier and I was planning on putting in a sub later, how many channels would the amp need to be, and a ball park range (a kenwood wOOx to a semi powerful 10") of how many watts would it need to be able to handle?
(I'm not sure what I'd do without the audio guys on this site, thanks for all the help)
Well, the amp question depends on what you are looking for. As others have stated, the Infinitys will sound better with a good external amp powering them. The stock will do, but a dedicated amp can mean the difference between "sounds good" and "sounds awesome."
As far as installing a sub later on, you have options here too depending on which route you prefer to take. The Kenwood wOOx is self-powered, but rated at only 60 watts. However, it's still a pretty sweet sounding sub, outputting tight bass that doesn't sound boomy and won't drown your mids and highs. And since you might be able to install it under the seat, you'll "feel" the bass just fine.
If you are looking for authorative bass, you will need a set up in your cargo area with nice custom enclosures and a dedicated amp for the sub(s).
Alternatively, you can do what I did in my last car. I had the head unit drive the speakers and installed a stand-alone amp for the bazooka sub. I was running Diamond Audio speakers and found that the HU supplied plenty of juice to drive the speakers. However, I did toy with the idea of installing a 4 channel amp that I was planning on splitting between my rear 6x9s and the sub. I was going to bridge the HU to power the front 6.5 and tweeters. Unfortunately, they broke in to my car and stole everything...so I never go that far.
2-way means that the speaker has a woofer and a tweeter. 3-way means the speaker has a woofer, a tweeter, and a supertweeter for the really high notes. It's easy to tell them apart, just look at the thing that sicks out of the center of the speaker and if there is one little dome thing there then its a 2-way, if there are 2 there then its a 3-way.
Jesse1
