SCS Ray10's with 285's what what's your lift setup.
3s1kill
I just ordered some Ray10's for my 2015 limited. I'm cheap so I'm looking at the Falken Wildpeaks in 265 or a 285. I want to run 285 with a Daystar 2.5"/1.5" leveling kit but not sure if that's high enough not to rub.
If you have any 17" SCS please comment. I'm looking for people who have a -10mm offset with a 285 so I can finally order some tires. Pictures are welcome.
I searched around but only find 285 tires on TRD PRO or FN FX Pro wheels.
This guy has a stock lift with 275 70 17 tires on his ray10s. Minor rubbing
http://www.toyota-4runner.org/showthread.php?t=241719
How did you order them, thru their website or did you call? They seem like they're always sold out.
I’m running 17” Ray 10s with 275 70 17 BFG KO2’s and I get rubbing on the rear mud flap at almost full lock.
They have a subscription thread that tell you when they are in stock. SCS said they won't have more until Mid May. When you order it is online only and you better have quick fingers or Apple pay/Samsung pay remember your payment info cause they sell out within 2 minutes.
I have the Ray 10's on 285 Falken Wildpeaks, Icon suspension all around, and Wheeler's T13 rear coil. I was rubbing while turning left or right on the front mud flap. Removed it and it took care of that rubbing issue. Had to do the wheel well mod and trim some of the front bumper to avoid rubbing in reverse.
Thank you for chiming in. It's a good thing I didn't get the 285's then. I was looking at the Icon suspension but that's out of the questions right now.
I have 285’s with a Icon stage 2 and no rubbing. I did set the front coilovers to the max height and had the caster set high so that probably helped.
I have ray10's with fallen wildpeak 285's on a toytech 3"/2" lift. Getting slight rub at full lock reverse on the body mount......I removed the front mudflaps and trimmed the bumper.....
That’s odd. I have SCS SR8s with 285 KO2s with Radflo coilovers and have zero rubbing with my caster set to 3.2 degrees on both sides
Yeah, I’m told I chose the wrong UCAs (Icon tubular delta joint) and they prevent me from being able to change caster. So...body mount chop coming up.
I'm waiting on my Icon lift to arrive, I also ordered the billet UCA's. I plan on running the Cooper Discoverer AT3 XLT 285/75. Hopefully the adjustability for the caster will alleviate any rubbing.
Ray10s with 265/70R17
I'm currently running Ray10s with 265/70R17 Goodyear Fierce Attitudes and Icon Stage 5 3" lift. Prior to the lift install they rubbed at full lock.
I have about a year left on these tires but when they are done I plan on moving up to 285/70R17. I expect that they will rub again and I will need to do the whole "cutting of the mud flaps/bumper" thing.
Scs 17
I currently lifted my T4R this week. I have a SCS F5 offset -10 with 285/70/17 Cooper Discoverer STT. With Full Kings Suspension setup. Lifted factory height 2.5' all around. No rubbing due to mount chop mod and front fender chop. No rubbing. im not 100% sure but i think you can go by a level kit and do the mount chop/Front chop and you'll be fine.
Crookedcat
