Antman
Elite Member
Yes See his photo on 1-1-2013.
The photo doesn't show if the bars on the dials light up. They illuminate orange on the factory seat switches.
not sure if I am talking about the same thing, yes, the yellow indicator lights when you turn it on, the bar to the right of the dial lights up green all the time. sounds like you will have to perform one of your LED modifications.
Actually I'm talking about the
little white strip on the dial itself. It doesn't appear to light up like the factory switches.
On another note- you posted this about the wiring:
"The wiring schematic is as follows (this was found by trial and error - the manual the seller sends via email is crap):
Red: Constant power from the battery
Black: Ground
Green: Switched power (control box acts as a relay)
Yellow: Illumination"
Since you connected all your yellows and greens the switch is lit all the time. Seems to me if you connected your yellow wires to a dash light circuit they would only come on with the lights.
I guess I'll find out tomorrow! I'll post the results here.
Shame you weren't doing his tomorrow, I am in Laurel.
Jnance, yes, we did have the same kit, if you look back 1 or 2 pages, I think we ordered the one someone posted earlier in this thread. it took a while to arrive from china.
I have all the tools I could possibly need, I just dont like working on my car in the parking lot here where I live, I was going to try to install the heating pads without removing the seats, but the more I look at the photos and read, it looks like that is the best way.
Actually I'm talking about the little white strip on the dial itself. It doesn't appear to light up like the factory switches.
Black: Ground
I'm thinking these could possibly be a great fit for the rear seats...![]()
Question- do the white indicator bars on the dials light up?
I'll be installing these on Kraeken's TE on Monday. Keep the pics coming! More pics=less time figuring stuff out for me.
Antman,
The white strip you're talking about does not really light up, no.
And the reason you can't connect green to dash lights is because it has to have power for the warmers to work at all - it acts as a trigger for the internal relay AND as illumination for the green side bars. Also, the yellow wire only lights up the yellow "on" indicator - so you wouldn't want to to tie that in to dash lights either (atleast on my kit that's all the yellow wire operates) .
Hey thanks for finding the correct wiring for the switch lights, where did you tap into the dash lighting?
I would like to know as well. I could easily pull my yellow wires and tap them elsewhere. I could've sworn when I test wired mine my yellow wires didn't control the illumination of the green bars (which I thought was weird).
Also, Antman, do you know if you tap them into a dimming circuit if they'll dim as well?
