There are 3 options. You skill and budget will determine which one is right for you.
1. Build your own via Tundra Forums instructions (requires free registration):
TundraTalk.net - Toyota Tundra Discussion Forum
2. Get a kit that requires you to cut wires, aka, the SlyFox kit. It is $45 but I you must be comfortable cutting at least one wire. Jeff is a great guy and he was very helpful over email even though I did not go with his kit.
3. The plug and play method. Their are two kits - RuTech ($180) and Hewitt Tech ($225). The big difference is the RuTech does not have a starter wire, so the relay will not work if you put your truck ignition in the ON (but not Started) position for more than a few seconds. Hewitt has the started wire, but it requires you to put it under the starter relay. Hewitt might need a wire cut as well. You can check their website.
I went with the RuTech as I want plug and play with no cutting. I will be installing the block off plates as a redundancy, so even if the relay fails, the pump can't function anyway.
