Thanks DavenLei! You should get many years out of the bypass! Enjoy.
hey slyfox75,
I read few pages, I got the p1442 code with bank 1 stuck close, that means I dont need the plates correct? Also, do you have a DIY/Video/Pictures on to how to install your kit? also whats your paypal or venmo? I'll send over the payment. How much is it?
hey slyfox75,
The instructions in his kit are very thorough, with pics.
Didn't see this thread before, lucky timing for the sidebar. My valves were stuck open, I was able to get them closed, I thought, and installed a bypass but recently the codes have been coming back.
Has anyone else had the codes return with or without installing the blockoff plates? Read a bunch of pages but not seeing any mentions of it.
Was considering trying a higher resistor before blockoff plates. I started a thread here https://www.toyota-4runner.org/4th-...-air-pump-codes-after-bypass.html#post3413881
[MENTION=58630]jbtvt[/MENTION]. Resistor change wont help.
Do you know what codes you are getting? Depending on codes we can pinpoint what you need. Could be something completely unrelated(O2, evap, ABS, etc)
I see a lot for the bypass kit, however I’m about to do some major surgery anyways on my 06 T4R Limited and am wondering if you can just remove the whole system all together? Is this a realistic possibility that isn’t more than a bypass? What is needed if so?
You have a 9 year old truck and you experience a problem, now you want it covered under warranty when it expired 4 years and who knows how many miles ago?!? When they don't you say," I will never buy a Toyota product again", even though you like it, until the possibility that you had to put money into it. Unless of course they give you something for free LOL.
This is borderline crazy, put any other product into the place of your 4runner. Not many companies are going to willingly replace something 4 YEARS outside of the original warranty period.
Listen, most of the times this is an easy fix, and can be done in a few hours with hand tools for NO money 90% of the time.
The inlet pipe for the air pump has a foam filter, which over time with engine heat cycles,starts to deteriorate. When it does it gets sucked into the pump (occasionally damaging some fins in the pump, generally not enough damage to cause the pump to not work), and push the little bits of chopped foam straight into the valves. This causes them to stick.
Snatch off the intake, remove the foam filter, and blow out the pump with compressed air. Remove the valves and use a power probe (or a jumper wire from a 12v source, IE your battery) to actuate the valves and remove any pieces of foam stuck. Then reassemble and you're done. Iv done this to countless tundra's and 4runners and have had VERY few need actual parts replacement, although occasionally it is necessary.
Also, LOL @ responses to get the government involved.
Not to nitpick, but the warranty enhancement isn't because of defective airpumps. Its root cause is water intrusion leading to parts failure.
You cannot remove entire system with a "regular" bypass. Well.....you can. You will have CEL and multiple codes however.
You can check out Hewitt Tech website and ask Paul(owner) he has a new system that I think allows you to remove entire system @~$500 range. Most people just leave it and bypass it.(easy/cheaper/no real advantage to remove)
