shocks/lift/spacer questions
mikehinthehouse
hey guys, its been a while since i have visited.
long is short is i have been reading all of the stickys and post about shocks and lifts there is so much information i think i have confused myself.
I have a 03 limited 2wd w/o xreas
the shocks are still stock.
I would like to do a small spacer lift, something like a 2/1 just to make it level and lift it up a little bit.
My stock shocks are wore out and need replacing at the same time. I am trying to do this and not break the bank. Do you guys think I should just buy shocks and spacers and be done with it or is there another easy/cheap option to replace the whole shock/spring setup and still get some height out of it?
Thanks for your help.
Since you are going to replace the shocks anyways, I would purchase a set of bilstein 5100s and a Daystar 1" rear spacer. I think that will be your most cost effective setup. The front lift you can set with the Bilstein's adjustable spring perch so you don't need a spacer in the front.
Will there be enough lift in the bilstiens
to level out that squashed look in the front when putting the 1 rear spacer in there?
May be confused by the 5125's which have longer length, you will not need those with such a small lift. You should be set with the kit that was linked to you. You cant go wrong!!
BillM777
