Should I get a spoiler?
Should I add a spoiler?
  • Yes definitely
    Votes: 26 66.7%
  • No
    Votes: 6 15.4%
  • Maybe...Wont really add much to the truck
    Votes: 7 17.9%
  • Total voters
    39
Yeah i'm planning on getting a hump one. Can anyone else verify that you don't need a different lift gate to install an OEM spoiler?
and is the 3rd tail light LED's?
No, you shouldn't need a different gate.
The only reason that I can think of that you would need to replace your lift gate is if you installed a aftermarket spoiler that had the mounting holes in a different spot and wanted to replace it with a OEM spoiler. Even then that is only if you could see them or if it would cause a mounting issue of some sort.
From the response I got from partznet they sell the OEM (Hump) style spoiler.
They are a little cheaper then the dealer, they charge about $560 where the dealer seems to be in the $700 range.
If you go to partznet, once you select your year/model, just click on "Lift Gate" on the left, then Spoiler>Spoiler Assy, and select your color.
becareful of the ebay sellers.
I've found several that displayed pictures of the OEM spoiler w/ the hump, but when I asked them if it was OEM or not they said no.
Most of them tend to have spoilers like the one in T4RsRGR8 pic above.
Pls tell me im not seeing things. Yesterday on the Capital Beltway sitting in traffic, I saw 2 silver runners both of them 4th gen either 04 or 05. One of them was a V8 Limited and the other was a Sport. But both of them had a spoiler with a hump. I thought those only came on 06+? Is this correct?
bobbyavidity said:
Alright thanks! Good to know, I'll talk to them before I buy anything. I definitely want OEM.
No one is making aftermarket spoiler WITH the hump. As others have said, sometimes they show pictures of the spoiler with the hump. I had to return 2 of them and it was a bit of a fiasco with both. The problem is these people don't realize there is any difference hump/no hump - they are clueless! So be careful. I was never willing to spend the $700+ for the OEM and I don't want one if it doesn't have the hump. The $560 is a good price if it really is the OEM verision.
Jason Burtman said he can get the spoiler with the hump made if he can sell 20 of them for $399 painted and shipped. Check this thread
Correct,
Post here if you are interested in the hump spoiler, pic also in this link.
http://www.toyota-4runner.org/showthread.php?s=&threadid=51716
I might get rid of my OEM hump spoiler as it bumps into my kayaks on the roof rack... and I'm sure it will bump into the ski box I'll mount in the winter. Wonder how hard it is to remove the spoiler and fill the holes and get a third brake light.
Filling the hole would not be so much fun. Most body shops would probably bondo it, some might tac in some sheet metal but I doubt it. If the T4R came from factor with spoiler the third break light location in the gate would have to be removed. Might be more trouble then its worth after filing, shaping, prep and paint.
What about getting a spoiler that doesn't have the hump? Like the pre '06 version or an aftermarket?
BillM777
