show me your off road lights
Mind the poser garage shot.
Front:
Lifetime LED Headlights
LED Corners
PIAA 510 Fogs
Rigid E-Series 30" Spotlight/Floodlight Combo
Rear:
Rigid E-Series 20" LED Spot/Flood Combo Light Bar
I keep the rear bar off for daily driving. It would be too tempting to turn it on and blind tailgaters. Plus, thieves.
f3b47fa8-435d-41fa-9655-88ce1198420c_zpsa65f05fd.jpg~original
How did you run the rear led bar wires ?
Through the hatch and back up front with my CB antenna wire. The rear hatch seal seals decently even with a wire in it. I sent it through a high powered car wash and it held up. I ran my front bar wiring through the sunroof and that held up fine, if the rear leaked I was going to just route it up there too.
Mind showing how you mounted the rear light ? Any tips on mounting a light to the rear roof rack ? A led bar or single 2"-6" led light.
Here's a pic of all my front lights:
2000_zpse67d5840.jpg~original
Description and light output pics:
35 watt HID projector TRS retrofit headlights, low beam:
IMG_0115_zps42ee79e3.jpg~original
35 watt HID projector TRS retrofit headlights, high beam:
IMG_0116_zps6df13a02.jpg~original
Pair of Rigid Industries Dually D2 amber fog lights inside front bumper:
IMG_0117_zps6b824f08.jpg~original
Pair of Ebay 60 watt round LED long distance offroad lights and pair of Rigid Industries SR-Q spotlights on top of front bumper:
IMG_0118_zpsfcddb553.jpg~original
Pair of Rigid Industries SR-Q spotlights and pair of Ebay 24 watt 3x3” cube ditch lights (there is more light at about 45 degrees outward from the truck that doesn’t show up in the picture):
IMG_0119_zps0e608d53.jpg~original
Pair of Rigid Industries 6” single row spot lights on roof rack:
IMG_0120_zps8f5d7370.jpg~original
All front lights on:
IMG_0121_zpsfde0b16e.jpg~original
And just for fun - All lights on:
IMG_0126_zps7d7524c8.jpg~original
IMG_0129_zpsaac05957.jpg~original
IMG_0131_zps44e1b979.jpg~original
Well I have a Whitson Rack, he made provisions for it to bolt up. I'd walk around home depot and see what I could use to make it work if I didn't.
my 2000. 30" combo light bar up front with 1 6" on each side and 2 in the back, plus the hid" and driving lights in the bumper.
30" curved light bar all spot reflectors. Bright as hell, pictures of the output don't do it justice, just as with most light bars it seems. Really makes my headlights look old and crappy.
Mounted it to the radiator support with a homemade bracket--couldn't find a premade bracket that would work anywhere.
Special thanks to
Code:
@Moroney167
and
Code:
@1blink
for helping me with figuring out how to mount it and wire it.
Front:
LED Corners
PIAA 510 Fogs
Rear:
off topic, but what tires are those? I like the thread pattern. Are those Toyo?
Well I posted in here asking for more pictures, so now that I have a light bar I can help out and post my own pictures! It's a 37" single row bar. I'ts insanely bright, and I'm really happy with it. I'm already looking at places to mount more of these light bars. Once the weather warms up a bit I will be taking the brackets off and cleaning them up by rounding the edges and painting them black. I think they came out pretty good for being made with a piece of aluminum, a vice, hammer, and drill.
I'll join. Need to get new pictures since finished but plan on sunrise wheeling tomorrow hope to get some awesome ones.
20" lightbar from OKLED. Mounted super easy to cross member in front of radiator. Also have LED light bulbs in headlights from him as well. Highly recommended.
Do you have any pictures of how you mounted it? Im trying to do the same thing but I have the "Dealer Installed" Hella's as well, and I'm using a 24" bar.
Rigid Dually Floods with CBI ditch brackets. I have these pointed slightly outward to fill in the dark corners on the twisty trails.
With the lights mounted on the hood like that, do you get any glare off the hood? I had some lights mounted on a light bar in the back of my pickup and he glare was horrible. I ended up taking them off.
I don't notice any glare at all, but I have these floods pointed slightly out to get some light in the corners on the twisty roads. I keep them tight enough so they don't move, but I can do a quick angle adjustment by hand depending on the road.
Here's a few output pics of my light bar. The high beams were on with the light bar, but they really don't make much of a difference. The light bar puts out some serious light.
