Snow in Maine, 2000 4runner limited
My mother just bought a farm in southern vt. I'm not sure where in vt your at but maybe you could suggest some good wheeling locations out there.
If you want we should plan a camping wheeling trip. I know some other guys up here that would join too.
Front skid plate is almost complete. I need to weld the side protection on. It's all 3/16 plate has steering rack and camber bolt protection.
1f753a83a1f9595574fa85aa237dff88.jpg~original
b150921cab44fbe3278e22c8a511a734.jpg~original
b14bb68392f8772020c65dac4f73efba.jpg~original
Looks good man. I have the exact same Runner. Color and everything. I would love to put some work into him (just have BFG's ATs on there) but it's hard to do that considering I live in the dorms (USAF).
Yeah barracks suck but does your base have an auto shop? Or start hanging out with other guys that have work done on their trucks.
Just the vomit you see on the floor every now and then lol. Yeah we do but I'm pretty sure it's just a shop to do general maintenance but I could be wrong. And I'll start mingling around the other guys
Here's another update it's only tack welded together until tomorrow. But the sides are in place
f323fb66816424f08fa2afeace23f24d.jpg~original
96f0f8b64bd3b6dc501a1347c56240e4.jpg~original
Just as I wanted it tight to the body keep the approach angle steep
5ad6911be9bd94dcc184c2415dc52299.jpg~original
589f45edb1fd748bf994e2ea428b66ec.jpg~original
Both bumper and skid are mounted to the front crossmember and either can be removed while leaving the other in place.
40948492852cde09ff0281aaebfb5ae1.jpg~original
Here's how far it sticks out from the front of the truck
4345cfab403dcad3fe8bee5f0d84773b.jpg~original
As compared to AOR
cef66be89cf07d7e7f311dac47788826.jpg~original
And one of the skid
e4799af8fe9477be618bf0198d8f709b.jpg~original
Lastly another 18-26" forecasted Sunday!
Went out today and tried my hand at deep snow wheeling. Didn't go so well. Got hung up multiple times, and had to break out the shovel. We were trying to go through 24-30" deep snow drifts with an icy bottom. So maybe that was our problem.
29DE7409-F129-49CA-B0D0-E722D79DE154.jpg~original
56C418C4-1F9E-4E3A-800A-7F41D4296DB2.jpg~original
94CA3629-414C-4408-8E2E-77BC689269F3.jpg~original
CD6691B3-58CD-4C8A-85FF-9564673BE7B5_1.jpg~original
F5B14569-7811-402F-B5D8-6112BD132912.jpg~original
Luckily they plowed this drift
0912E277-4743-42BF-902B-BB5B510F0DE6.jpg~original
On a side note, taco whip in route along with more LEDs and e locker guard thanks [MENTION=44220]BigFishAllDay[/MENTION]
Deep snow wheeling is tricky, there are so many different factors that come into play. There are good days, and not so easy days; but it's always a good time! (for the most part) I really like the build, keep up the good work!
Thanks dirtco for the compliment, I've been following your build closely. I believe it is a well thought out build and not something pieced together like a lot of the other builds on here. Thanks on the inspiration to make the rock sliders. I know I'll be borrowing some of your other mods, like the ditch light under the slider.
As for snow wheeling, I had a blast and looking back at it I think I know the main issues with the day. Although I thought the skid plate would help me float on the snow(which it did) combining it with not airing down enough let the tires cut and high center. Problem number 2 was all ice on the bottom. once the tires dug the snow away I had zero traction. Lastly a locker would have helped a lot.
I'd really like to step back to a 16" wheel and step up to a 35" tire get some more float action. I ended up selling the 1" body lift so it looks like I'll stay low and try to clear them.
Went snow wheeling today. Had some fun, did a old of drifting. Got stuck, buried it. Used the shovel and a tacoma to get out.
EA7A1F70-15FC-49E1-9E1B-D1A20DE8A2BE.jpg~original
F3349055-F19A-4A5A-8E5E-F659A8656D7D.jpg~original
600217D5-978D-4415-A618-90F81A8055A6.jpg~original
Ran the tires at 8 psi got a good amount of squat
47F62BF6-4F9F-4162-BEA6-04167497A6B0.jpg~original
Partially re did the side pieces of the bumper
77D6E04C-B619-4D19-A803-330D103D9482.jpg~original
Finally got some time to work on the bumper. Just about finished, still need to add the small light light bar hoop. I have the steel pipe just no way of bending it. I guess I'll have to go to a shop.
Anyway 1 coat of chassis saver paint on.
0bf11d1c5d90615e24d402696fe72564.jpg~original
b8e3dcc18759473781a8a75499082a07.jpg~original
28c96db9b8327444d52fb17c19d93b65.jpg~original
Can't wait to bolt it up!!!!
I still have enough steel to make a gas tank skid!
I don't think 15" wheels will clear the front brakes since you should have the larger of the stock brakes, but I could be wrong. That bumper looks fantastic!
I'd have to grind the face of the caliper a little bit. My buddy is running 15's without grinding on his 03 tacoma trd which should have the same brakes.
If neither works than it will be tundra brake upgrade and once these tires die 35's.
Taco whip mod complete! Also tightened up the valve cover gaskets, they seep a little oil in the cold weather.
E locker standing by for install
Skid plates bolted in place with 3" high side protection re-enforced the backside with some 1/2 " square bar. It's solid.
Today I installed lower ball joints. I can finally sleep easy. From what I can tell the lower ball joints were replaced at some point and weren't in bad shape but they definitely were not oem. Also placed an order for both inner and outer tie rods. They have gotten worse and in serious need of replacement.
I also was board tonight, so I removed the factory spare that still have the nubs on the lugs of the tire. In similar un used fashion it was completely flat. Then removed the hitch. Soo much more room under the bumper.
And one poor picture.
Great thread man. Very nice build.
Wheeling in deep snow can be tough. I tried going into 1-2 ft snow on the trail in big bear and nearly got stuck.
2001ATL
