So I Monstalined my Runner
opie74
Everything went very well. I ordered the 2 gallon tintable kit and then ordered a 3rd gallon kit just in case. Heres what I learned for anyone else wanting to tackle this....
1. Its easy. I rolled everything on and aside from some splatter on the glass etc, it was a breeze. I removed all the trim and lights to eliminate as much taping as possible. Pulled the doors and rear glass weather stripping as well. Everything else got taped which took about 1 hour and included the headlights, paper over the front grill and bumper, the rubber gasket around the rear side windows, the windshield washer nozzles on the hood and rear gate.
2. Plan accordingly. Its been humid here the past few weeks and I was waiting for a break in the humidity. It ranged from 70 to almost 90 with the humidity between 60 and 70%. They state recoat time for the tintable liner is between 2-4 hours, but is based ultimately on temp and humidity. The product in the roller tray was skinning up as I was using it and I started my recoat as soon as I finished the first coat. I ended up getting 3 coats out of the 2 gallon kit with 1 tray of product left over. I believe I can attribute most of that to putting the first coat on way to thin. See next point.
3. Put it on. I rolled the first coat on like one would normally roll regular paint. Trying to stretch it out and blend everything in. Forget what you know about rolling regular paint. Lay it down and lay it down thick. If I had done the first coat like I did subsequent coats, I believe I would have used most of the 2 gallon kit and not had any left over, in 2 coats.
4. Pass on the Monstashades color. Its cheaper to get the color locally even if you aren't trying to color match. I got 2- 8 ounce cans of Sunfire Red tint (no binder, reducers etc. JUST color) for $37 total. It would have been $70 to $80 to order enough red from Monstaliner, and that's not color matched. It may be different for different colors, though. Price check before you commit.
5. I originally took the entire rear end apart to put the Chassis saver on and had a few places on the body that needed treatment too. If you are planning to go over some rust on the visible parts of the body that will get bedliner over it and you aren't using black Monstaliner, get the Aluminum Chassis saver. I had to roll over the black Chassis saver 4-5 times to cover up the black. Maybe 8 ounces of color wasn't enough? Fortunately I wasn't trying to change colors otherwise I probably would have had to use the 3rd gallon I bought. Plan accordingly.
6. Pull your tape as soon as you can after your final coat. I did not have any issues, but can see how it could become an issue. If you pull the tape in time, the liner will blend into the tape line.
This looks really good! I always rag on the guys that say roll on doesn't look as good as spray...it's just a lot more work. I was planning on using monstaliner to do my rocker panels and roof but I'm wary about how many coats I need to do to get the texture right. I'm asking a bit much, but with three coats how many quarts per sq ft would you ball park using?
The only reason I rolled it is I did not want to take the time to prep for spray. I guess in the end it probably would have taken the same amount of time, but rolling worked. It also allowed me to create a smoother texture by rolling the last coat very lightly. I just pulled the roller over it with no pressure on it, just the weight of the roller.
Well, I think I filled the tray 4 times from 1 gallon, so that would put 1 quart in the tray each time. This means I had 1 quart left over when I was done. I say this, however, after putting the first coat on way to light. If I had put the first coat on heavy, I think I would have used all of the 2 gallons and only had to do 2 coats.
Quarts per sq-ft..... the hood probably took just less than 1 quart. Im pretty sure the roof took a full quart.
Do you have more pitcures you can post up? I really like what you did!
I will get some, any particular shots you would like? The color has seemed to deepen during the week. Im not sure if its because of the lack of gloss or if its really darker.
Where did you pick up your tint? Did you have the tint matched to your original color?
I bought the tint from a local automotive paint supply. I believe it was PPG "Shop Line". I can check one of the cans tomorrow.
I did color match according to the color code on the door sticker.
So all in how long did it take and how long between coats?
Aside from all the prep work, from the time I popped the first lid on the first can until I finished the third coat was approx 4 hours. The temp and humidity on the day I did it allowed me to start the next coat as I was finishing up another. So I had no down time between coats.
If it's not too much trouble maybe the roof? Did you remove the roof rack or just tape it off to paint around it?
Ill get one tomorrow. I neither taped it or removed it, I went over the sides of the roof rack. I originally did not intend to do that, I was going to tape it off but figured Ill never take it off, and I am not worried about what it looks like so go over it. Yeah its a little sloppy, but I did just cover the entire rig with bedliner.
No more scratches for sure. :clap2:
None that matter anyway!
Actually how did you pick out your tint? I was on the ppg page and there are several blues listed, but I can't find a vehicle match or color sample section.
I forgot about pics of the roof, Ill get them today.
You color code is on the sticker on the center pillar when you open the drivers door. Bottom left corner.
Joining the club! Now we can have some t4rs represent monstaliner unlike all the jeeps :mad, I'm glad you rolled it vs spray so people can see the different textures now from looking at our rigs. Good job man!
I had been thinking about it for awhile prior to seeing yours, but you did give me the motivation to get it moving.
Here is the roof.....
Here is the can the tint came in.....
And just for giggles, I pulled this out of one of the trays I used......
If you don't mind me asking, how much did all of this run you?
Alright, just off the top of my head because I've already forgotten the hard numbers......
The 2 gallon kit from Monstaliner was $250. Tintable or straight black is the same price. The tint to color match was $37 and covered both gallons. I bought 2 quarts of MEK substitute @ $10 each but only used half of 1 quart. I bought 2- 2 gallon pails to mix each individual gallon in and they were $3 each. That's about it. The kit comes with everything else you'll need other than paper to mask off.
Sent from my iPhone using Tapatalk 2
