So you like bass do ya?
I can't recall the actual dimension specs on the Anarchy's, but I was able to fit 8's in my front doors that are almost 4" in mount depth and have a very large diameter magnet structure. Didn't have to mod the door sheet metal at all, but did have to use a baffle thickness of 1" so the magnet would clear the window when it was all the way down. They still fit below the OEM door panel with only minor interior panel face trimming. Looked completely OEM on the outer surface.
I went from the OEM 6x9's to just some aftermarket JBL 6.5's, then went straight into the high end 8's I run now and I'll tell you what, even though I have not heard a high end set of 6.5's in these doors...I would have a tough time going back to a 6.5 after having a set of high sensitivity pro audio style 8's as my midbass. The key to good sounding door woofers/midbass is in the door treatment itself. Sealing off openings, adding deadener, CCF foam, and MLV (mass loaded vinyl) are some of the things that will turn your door into a much more efficient enclosure.
Even though you think you don't want to add "bass" up front, that in essence is exactly what you should strive for...but not the bass you're thinking of like what your sub delivers. Your front midbass should be able to handle playing down to 70-80hz and the sub should only pick up from there. If your sub is crossed at 80hz and the front midbass is not playing with authority down to at least 80hz, there is a lot of bass punch and kick that you're missing out on from your front stage.
Exactly, I'm probably going to run a pair of american bass sealed back 6.5's in my front doors and run them on a Marc Anthony gs380.4. Might have to find some mid bass drivers in the near future to fill between the sub stage and midrange. Will really need some mid bass, might do some 8's as well
Built an enclosure for the 15's in the 4runner today. Shouldn't be too bad on 2.5krms... need to get he ports in and batteries, 2/0 cable is here so gotta run that as well. Swap head units, drop in woofers, and volt meter in the dash, slam the amp in and should be playing by Tuesday! After that I'll worry about making it look good. Probably long hair shag for now, might plastidip it later though...lol
Yeah, dual 8" aeros. As things stand now I'm looking at 29hz tuning before the effect of port loading on the rear hatch comes into play. Its all together except power runs currently
Can I get some dimensions on that box? I have a '16 sr5 I'm tearing out my wall of 4 15" NEP Audio HD Maxx v2 and putting just two in while I recone 2 with sundown nightshade voicecoils, and need a box that will sound good and fit nice and snug like yours. I see its 2 8inch round ports, how long are they? And just dimensions of the box, my guess is 24" tall 40 wide 20 deep?
AndiGarage
