jrandom
Where about in the engine bay? Firewall?
Just cab-side of the battery.
EDIT: added image...
[MENTION=83083]rigtec[/MENTION]
Hey [MENTION=2839]Akkording[/MENTION] ,
Looks like [MENTION=106009]flybooey[/MENTION] got the answer(s) that he sought! It would've taken some time to "Ring out a problem like this"; what, with the electrical and "CAN-bus" system; to say nothing of the firmware/ecu diagram study, hands-on operations, and the schedule work-around!
But you guys had everything under control because everyone was really thinking, and "NO ONE" was just guessing some random (bull-shipp stuff), lol! BTW: Should there be anything further that I can help with, Let me know! 'Best to you ALL',
rig
When that is mostly "good news, bad news".
Did the dealership have any thoughts about what prompted the failure?
True....I never would have found the culprit.
I've heard of this unit failing with only the horn as a symptom; almost always associated with overloading by aftermarket horns. Never heard of it killing the whole shebang.
You may want to go back to the stock horn...Well..... I do have these horns that i installed in 2017
This sounds like an unusual failure and - since it is only commonly found with a mod you have - then removing that mod should resolve the threat.I think that may be a proper idea. I have this desire to also pick up one of those relays to keep on hand (or in my glovebox)
I mentioned it earlier, anything in the fusebox, other than the block relays and blade fuses, you pretty much have to remove the fuse box and pull the components out from the bottom. It's pretty ridiculous.
I'd just ditch the aftermarket horn and pick up one of those canned air horns![]()
How often do you use your horn to even require the need for a louder one? Yeah stock horns should be sufficient
I suspect you meant years (not hours). If so, then not being a horn honker is the reason that the magic box lasted as long as it did.This I horn swap was not a mod or upgrade but just a replacement 2+ hrs ago as the oem dual horns slowly failed to just one then none.
They are driven by the oem relay and not an external one.
And im not a horn a horn honker by any stretch.
The integration relay (unit K) in the diagrams is an exception. This little magic box is lifted out with all of the connectors attached and has enough spare wire to pull clear of obstructions.
As to relationship between aftermarket horns and this relay unit; If the horns are powered via an aftermarket relay and the stock one only switches the add-on relay I can't see any logical path to failure. However, if aftermarket horns are driven directly by the Unit K relay then who knows how they fail, but they do.
The internals of Unit K are a mystery, but I assume there is a circuit board with magic smoke devices and at least 4 standard coil relays. A mechanical horn produces it's sound by rapidly making and breaking contact on a magnetic coil so I can find some logic to them over-driving an IC that was designed for a lighter load.
