Sorry for so many ?'s and not many answers
jmrwd3
Hey all, its me again. Sorry for so many questions lately, I know i ask a lot a contribute very little. Hopefully when i gain more knowledge I can start helping out a bit.
On my way out to CO I noticed that my A/C was getting a bit cool and the compressor was switching on and off a lot, about every 10 seconds. I have since left the system off, but does this sound like low refrigerant or something like the compressor cycling switch? I know that i haven't serviced the system in the past 3 years, but am unsure of the previous owner. I am ordering the refrigerant pressure gauge, but in the meantime will i damage the compressor if I do run the system?
'99 4Runner 5sp 4x4
125xxx miles
get the Diagnostic Trouble Code (sensor)
compare it to the attached chart if it codes
Would the sensor tell me though if it was simply low on coolant? I think i'll stop at Autozone one of these days and just buy the gauge, it can't be that expensive. That would at least tell me if it is a r-134 problem.
since you said the a/c blows cold air, I don't think you're low on refrigerant. if it was, you wouldn't get cold air.
i'm thinking electrical; something is causing the magnetic clutch to turn on/off rapidly. maybe the clutch itself is bad. I don't know.
I would seriously recommend letting an A/C tech check it out if you want to avoid making the problem worse than it may already be... A/C components aren't known to be very durable and are quite expensive to fix.
