Sound system and rear view project
Foques
Hey all.
first of all, I did search. Nothing turned up for this as far as I could see..
I plan on changing the speakers out in the truck.
I already have on order Boston acoustics SR65 and 60SE components, headunit and dynamat, already have a diamond 12" sub, already have amps, and wiring..
What I need to know is:
1) Where can I find spacers for the speakers?
2) Are there any generic t4r specific subwoofer boxes available around?
3) Rear view camera.. does toyota use a different rear garnish to fit the camera or do they use the same garnish and just do or do not stick the camera in there? ( i want to run a separate LCD screen for the rear view only, and want to get my own camera)
thanks in advance.
Hey all.
thanks in advance.
Congrats, I am sure you will be much happier with the sound after you are done!!!
1) I think the easiest thing to do is make the spacers yourself with MDF and a jigsaw. But I have heard of people buying them on Ebay and also at Tacotunes.
2) I have not seen any specific 4runner boxes out yet. Everything I have seen has been custom fiberglass enclosures.
3) Sorry, cant help you here :)
Good luck and make sure you snap some photos so we can see how it turns out, especially amp mounting and the box.
Thx
#3 Toyota does use a different garnish for 4Runner handle panel with B.U. Cam.
Pilot, do you happen to know what the difference is? Is the difference only the little hole/slot for the camera, or something in the actual "meat" of the garnish, too?
Looks like I may have to come up with an alternative fitment solution unless I can just cut the garnish..
another question..
How big of a difference is there between Metra kit and, say, scosche?
I know metra build some crappy quality stuff when it gets complex.. (say, a kit for my current car is known to fall apart)
ok, truck is arriving this wednesday.. :)
Did anyone get the steering wheel controls to work with an aftermarket stereo? which controller was used?
It appears that the PAC SWIPs won't work on 2011... :\
anyone?
Also has anyone hardwired their OEM rear view camera to go into their aftermarket stereo?
Liam14
