Bishop, here is what to expect:
SSO packs the rack pretty solid with plywood sides and serious foam
Although the box was scrapped by FedEx
The parts were intact
The inventory list was short on small screws
But I informed them and they promptly sent the difference. I was told SSO fixed the inventory list and you should be ok.
I had few issues installing the wind fairing and I was told they fixed the problems and made the adjustments and few redesign items and you should be ok here too.
You can either install the rack on the truck per instructions you will be getting it or IKEA together on a flat surface and then mount it as one piece on the truck.
I started with removing the truck’s OEM rack.
Check YouTube on removing the end caps
And take your time removing the bolts otherwise you will end up with parts in headliner
Get silicone
And press the aluminum spacers in per instructions
What I did, I used the OEM bolts to secure the spacers. Use a plier to hold the spacer otherwise it will rotate the silicone and damage the water seal
Do this with all 8 bolts and let it dry. By the time you’re done with the 8th bolt, the first one should be dry and you can mount the brackets
I did put silicone on each bolt to water proof it
From here on it should be fairly simple
Side rails:
Wind fairing:
Cross bars:
And voila [emoji4]
Have fun
