Spartan locker install and review
KidVermicious
Well-known member
A local wheeler offered me a Spartan automatic locker for $200, new in box, and while I was saving for an elocker, I couldn't pass this up. I just finished installing it.
Install process - difficulty is a 3 out of 10. If you can change your brakes or bolt on a new starter or alternator, you can install a Spartan locker. Time-wise, it took me about 8 hours over two days, but this was the first time I'd ever pulled my third, and I spent lots of time scratching my chin and drinking beer and consulting my manuals. Doing it again, I bet would be 3 hours tops. Uncommon tools you will absolutely need are a ft/lb torque wrench and a long punch - I didn't have a punch, and I went through two screwdrivers trying to drift out the rod that holds the center pin. Don't bother reading the directions that come with, they're generic garbage. Read the Aussie locker writeup on ZUKs site, gearinstalls.com, and just remember that you're not re-using the thrust washers. You will have to pull the ring gear to remove the center pin, but this will not affect your backlash.
Driving impressions - I'll be back to update this once I get this bad boy on some rocks, and again after I've driven it on a snowy road. Right now I've had it around the block a few times, and am impressed. I'd heard that it would click loudly, bang every time I got on the throttle, and bind up and chirp the tires if I didn't coast around corners. None of those things happened. It clicks quietly on tight corners, not obtrusively at all. I also don't notice it when turning and accelerating from a stop, unless I really punched it, at which point I could feel the rear not want to come around, but not bad enough that I chirped or scuffed the tires. At 1/4 throttle or less (ie, normal driving), I didn't even know it was there.
I'm totally stoked. I know it's going to add to traction off-road, and so far its on-road manners are much better than I was even hoping for. I'll be back to update as I get it in more situations.
You should still check backlash... anytime the ring gear comes out.
Want wait to see some wheelin pics! You get those sliders on yet?
Yeah let us know for sure how it is off the road. Those seem like the most economical lockers there are, I have been drooling over the e-lockers but I know my wife will never go for it, so the $300-$400 range is where I have to keep my self at
Your going to love the difference offroad! Having recently installed my Yukon Grizzly locker I can tell you that you will be able to climb far more places than you could without it. Have fun! Just don't get over confident like I did and break a CV.
Drove to work through 4 inches of snow, and to be perfectly honest, I noticed the TrueTrac in front far more than the Spartan in the rear. With the hubs locked, the TrueTrac is working to keep the front wheels spinning together, even while I was still in 2wd, so there was certainly some understeer going on. The TrueTrac also got kinda grabby at the wrong times once I put it in 4wd - maybe I'll get better predicting what it's going to do once I'm more used to it. On the other hand, the understeer worked nicely to counter the tendency of the rear to slide out when I "accidentally" blipped the throttle on a corner or two. :D
But the Spartan didn't give me any problems at all. A nice steady throttle and sane driving and I barely knew it was there.
That's good info, KidV! I was curious how the TrueTrac would do on sloppy paved roads--I already know a standard mechanical locker will mess with your steering, but I wasn't sure if the TT would. It appears a selectable locker in front is still the most desirable, then, as it would allow open-diff 4WD for pavement. Thanks for the feedback. Your combination should be awesome once you're on the trails!
"Messed with" might be too strong - a little understeer, and a tendency to not automatically come back to center while I was on the throttle (I think that was the "grabbyness" I felt)... certainly different, but not at all unusable. I did 50 on the slushy freeway with the hubs still locked in, and was confident with that. A selectable would certainly be better, but so far I think the LSD in front is a viable option for the price, where I wouldn't even consider an automatic or a spool.
Don't get me wrong--I would also still consider a limited-slip as a viable option up front, considering the entry fee for an ARB is pretty steep. I just hadn't heard any feedback on how they do on the road, so I was glad to hear yours. I was wondering how much push they would have under minimal-traction situations, and you answered that. Just like with a mechanical locker in back (which I have on one of mine, too), you have to remember it's there, and drive accordingly--it's the price that must be paid to have the traction you want when the road ends (if selectables are out of the question). I just appreciate having the additional info to go on--I bought one with a mechanical locker up front already, and want it out just in case I need to use that one on a wintery road sometime.
Update - got back from Canyonlands a couple days ago, and though I didn't get any technical trails in, I did lots of highway curves on US 6 and lots of high speed dirt roads. It was great on the freeway, I still didn't notice it at all. I can make the rear end bob if I really get on the gas in the middle of a high speed corner, but who does that? I suspect my Four Squirrels of Fury just don't have the oomph to make this thing misbehave on the street.
I did notice slightly less traction in the washboard sections, and had to slow down a bit. My shocks in the rear are wasted, I suspect that when I get around to replacing them and getting some proper springs in that won't be a problem any more, but in the meantime throttle + washboard + locker = fishtailing.
Still fully stoked with this upgrade, and looking forward to the snow clearing the trails here so I can give it a real workout.
Gonzaga Lobos
