Speedometer Calibrator
It will work by intercepting the ABS speed sensor signals from each of the wheels and modifying the signal. Pretty simple, but I wouldn't personally introduce 3rd party electronics (especially Rough Country) into my vehicle for not much actual gain. If anything goes wrong with that setup, you are going to get a CEL and 4wd will be disabled.
Older Toyotas used a speed sensor from the transfer case which you could intercept in the same way, but just one signal instead of 4, and wouldn't necessarily set a CEL.
Thanks, so sounds like you need to keep connected always. That was one of my questions
Yep. On the 5th gen the only option is to tap inline of the sensors and signal modification, since there is unfortunately no ability to calibrate, like on other makes.
If my calculations are correct it doesn't look like my speedo if off by much with my 285 ko2, just 2.2%.
Road trip data:
110.5 miles trip
283-170=113 Gps google
97.79%=2.2% off
tuṣṭāva
