Stock size BFG AT KO
Im thinking about getting some BF Goodrich AT KO tires. Stock size (265/70/17). Do you have these tires in this size? If so, how much was MPG impacted?
I have the stock size BFG's in a C rating. I get 22 mpg on longer highway drives, and just over 19 mpg in mixed daily driving. I put these on in the first 20 miles, so I can't compare them to the stockers, but I am happy with the mpg and performance.
I have C rated BFG ATs in stock size on a 2010 Trail Edition. Everything else is stock and my city mileage dropped about 1 mpg. Highway dosen't seem to be changed. It appears that the stopping and starting of the extra rotating mass hurts mpg. Once you are on the highway and cruising there is no big change.
What kind of tire pressure are you running?
BFG AT KO or Duratrac
So I'm looking at putting some new stock size AT tires on the 4R and like the BFG AT KOs and the GY Duratracs (Both in C Load Range).
I see what MPG you guys are getting with the BFGs, howbout the Duratracs? Looking at the specs, the BFGs are 47lbs and the Duratracs are 44lbs... the Duratracs supposedly get a few more revolutions per mile as well. Are MPGs better than with the BFGs?
Basically looking for good MPG in a good AT (sometims MT) tire.
I picked up a set of E rated LT275/70/17 and I think it's one size bigger than stock but I still get ~19mpg mostly highway. They fill up the fenders well. Good luck in your search
C's are perfectly fine even if you do heavy off roading. I went to moab with my C rated BFG MT and did a lot of off roading never an issue.
In fact my buddy ran C rated Yokohama all terrain tires and did not even air down the entire trip. Never an issue either. We did heavy rock crawling also.
E's are way overkill IMO.
E ride on road?
I'm trying to decide whether to pull the trigger on a great deal on E-rated tires but the majority of my driving is on pavement. I'm OK with a small hit to MPG but don't want a harsh onroad ride. How are the E-rated KOs on road for you?
I understand that load rating also has to do with sidewall durability and not just load capacity, but I run D-rated 285/70R17 BFG TA/KOs and those have pretty firm sidewalls and are pretty damn heavy over the stock tires.
Has anybody owned BFG AT KO's and Duratrac's? Would like to know your impressions of both, noise, snow traction, etc.
Do you need mod something in order to use 275 or even 285 tires?
Same here - got my 275's last week and then drove from Philly to Pittsburgh. ScanGauge said I got between 19 and 19.5 the whole way...I'm ok with that!
