Stolen spare tire....
krosno3 said:
Is this how it works? I was wondering how do they work.....So if I buy new sensor from dealer do I have to program it somehow?
Yes, the sensors are programmed for each particular vehicle. EX: you can't swap 1 rime/tire with someone else without the TPMS going off for both of you. They'll probably need to be reprogrammed.
How weird would it be if a 4Runner pulls up next to him in traffic and his dash starts flashing:arrow:
Man that's a real bummer that all this happened Krosno. Just reading through this thread makes me want to choke someone. It's disgusting to think of people going around stealing stuff off cars. A few days after I bought mine someone stole the Toyota plug off my hitch (not even close as bad as your experience but still aggravating). I got a new one right away and it's been there for months. Just wanted to say sorry to hear that happened to you. I hope when they cut it down it fell and smashed 'em a good one in the face!! :twak:
After reading this tread, I ordered the same one. Should be getting it by friday. I'd be one pissed of person if I came out and didn't find my spare there. :goinposta
krosno3 said:
This should work and it's only 40$.... It is too late for me but I will get this lock for sure when I replace my spare......I recommend this for all of You because You never know when and where someone will try to steal your spare tire...
I just bought one of these from my local Toyota dealer for $18.95! Looks real simple to install.
BTW - I also bought the locking wheel lugs from Toyota. Someone mentioned that Gorilla locking lugs from Discount Tire would work - they will not! (because they aren't the washer type lug)
I use those thick bike cables.
I use a nice coil of thick steel cable bike locks to go through the wheel and around the steel bracket. The thief would have to cut both the locking cable and the original cable to get the spare. Spray some lubricant into the lock to keep it working and use a zipt tie to put a plastic bag over the lock to keep the water and road grime from turing your lock into a rusted lump of steel.
sharp4runr said:
Yeah I saw that too and was going to post, but then realized he was looking for a Sport Edition rim
They look like the sport rims to me??!? Or am i missing something?
CV
Kmvreter said:
I must have got lucky. Mine came off the boat stock with a set of locking lug nuts installed. Anyone else?
Yup. That's how I got mine. With the locking lugs already installed.
CVs4Runner said:
Thanks...I'm checking ebay everyday...:D However this one is not from Sport Edition.. This is 5 Broad Spoke Design and Sport Ed. has 6. But thanks....
I will probably end up buying used rim with used tire without tire pressure sensore. I'll be able to fix spare "holder" because I found all pieces. It's going to cost me about 150$ and it is much less than getting new one from dealer (about 600$)... But even though I wont be able to see that spare, still, deep inside I'll know that I have used spare and I'm not sure if I can live with that......We'll see.
Kmvreter said:
Is that a Toyota part and if so is there a Toy part #?
No, it's the same brand as mentioned above - WenchLock.
I've got mine installed. Be sure to get the one with the bolt-on bracket. You will also need another, larger fender washer than what they supply. The hole in the frame is too large & the supplied washer slips through. There is also only one way I could find to make it work, and it has to be turned just the right way, but it will work.
I've taken some pix, and will try to post those soon.
Here's the best pix I have of this. I will work in the 1st hole closest to the winch, but has to be positioned just right - note the placement in the pix. It will go thru the lug hole at a slight angle, but the lock will engauge. I doubt anyone could get the tire down. Remember to get a larger washer to add to the one that is supplied, as the frame holes are pretty big.
I was thinking that this thread or a shortened version (maybe one with different options for locks) should be made as a sticky. This is a pretty serious/important topic. I remember doing a search on spare tire a while ago and reading through a thread where a bunch of people were commenting that it would be next to impossible to steal the spare off of a 4th Gen. Unfortunately and at Krosno's expense we now know differently. Just an idea :) . Mods/Members what do you think?
Jhunt
