Stolen spare tire....
considering that I live very close to where this original tire theft takes place, I ordered the lock from hubcapsplus once I read the thread today. Sucks about the theft, thanks for sharing the info with us
jbrhymer said:
Installation was a breeze, though one caveat. It comes with 2 washers, one to go on either side of the bolt. The one to go inside the casing was too large, it wouldnt sit straight. So i went to home depot and got a 3/8" stainless that was slightly smaller in diameter, and everything went smooth from there.
I had the exact same problem. The housing of the winch (or the guide for the jack extension) was too wide and the washer wouldn't sit flat. It was too late to run to the hardware store for another washer so I just went without the top one. Anyone see a problem with this?
Also, this was my first time taking out the spare. When raising the spare back in, I assume I am supposed to tighten the winch all the way, so the spring on the end of the cable is fully compressed?
Also I noticed the wheel doesn't sit parallel to the ground when in place, it is slightly tilted down towards the front of the vehicle. Is this the way it is supposed to be, or did I do something wrong?
otto,
I did encounter the same problem with the top washer. I just grinded a little bit off of one side so it fit above the hole. I did still use the washer. Also, the tire does sit a litte akward once it is raised up. I just make sure it looks as straight as possible and I tighten it the rest of the way.
TIRE STOLEN FOR ME TOO!
Cut cable, no tire. Can one fix this thing? Dealer whants $700!!! Forget that. I bet i can but cable and rig it up myself if i have to. Anyone know of any Toyota junk yards in the chicago area?
sharp4runr said:
$20 dollar spare tire lock or buying a Rim/Tire? hmm, you do the math :D
Of course I still don't have a lock :confused: :) :)
we both havent done the math.:)
its a must nowadays, i guess.
Coupon code for spare tire lock
Hello everyone, my name is Jack Sanders and I am with Hubcaps Plus. I wanted to thank you for mentioning us in your forum, it has sent a few customers our way. I would like to offer you a coupon code to use on the spare tire locks that you folks are using on your 4 Runners. I do not want to violate any of your forums rules so I will not post our url but the coupon code that can be used at checkout will be js4run0306 . This code will give you $9.00 off the heavy duty spare tire lock.
Thanks Again
Jack
sharp4runr said:
Thanks Jack! I'm sure you'll have a couple more orders coming in. Maybe even me if I can get my lazy but moving :)
Sharp4runr, I was just reading back over this entire thread and saw that you talked about buying one of these tire locks last year, almost exactly to the date:)
Zona4R said:
I wish I had seen this thread earlier.
That sucks about your tire. just be happy it wasn't the entire car. had my Jeep stolen twice. 2nd time was complete write-off. but it all worked out, i now own a 97 4runner.
For those of you who own the Winchlock system. If the key is tubular like the website says, beware. If they're anything like Kryptonite bike locks, they can be opened with one of those round white Bic pens. Is the slot for the key the same size as the pen? if so, take the empty tube, heat the end until it's soft enough, cram it in the hole, let it hardened, and bingo, $0.25 key opens the lock.
if it's not a round key and the sizes don't match, just ignore me.
Can the hubcaps plus guy address this please? Is it the same size as a Krypto lock round key or not?
Hi , sorry for the delay I was awaiting a response from the manufacturer. He has informed me that the heavy duty lock circle is a little larger then on the circle on the kryptonite lock.
Jack
Jhunt
