Stupid AC Compressor Plug Question
mphillips_90
Putting everything back together after doing timing belt. Go to plug the ac compressor back in and some how the wires actually got ripped out of the plug. The yellow-green wire is still in the #2 spot but I dont know where to insert the other 2 wires.
Can anyone look really quick and let me know? Im going thru the fsm but cant find a wiring diagram describing the color of the wires.
What year model do you have?
I ask because I have 2004 and it's appears to possibly be different on later year models, but I could only see for sure 1 of the wire colors and just part of the color on another wire because of the insulation tubing around the wires, I was afraid to pull on it to try and see the last one not wanting to pull the wires out of the plug, neither of the wires I can see are yellow/green, the wire in what appears to be the #2 slot is red/(maybe black), the wire in the #1 spot is red/yellow, the #3 slot I can't see the color/s at all
Ive got an 05 4.7
I checked my buddies 03 Sequoia and I think it matches what you have.
Ive got an 05 4.7
Sorry I couldn't help you, mine's a 2004 4.7 Limited, I don't know if it makes a difference on a Limited with the dual zone HVAC or not.
I took a closeup photo with my phone because I couldn't see it very well down in there otherwise and by enlarging it could clearly see the #1 & #3 on the plug, I don't know how to upload the photo from my phone onto the forum, but it appears it won't be of any help anyway.
mines a limited as well. the 3 wires on the compressor I would assume are the start, run and common legs, but then again, I dont know much about auto HVAC systems. Cant imagine itd be all that different.
you can email the pic if you want
I don't have email setup on my phone, I did figure out how to upload the photo from my phone but I'm guessing the image is too large and after trying several times and it fails to upload each time, but the wires are definitely as I described in my first reply.
erinobr2000
