sub is blown?
dannyg
I noticed the stock sub has been making rattling noises, im sure it is blown. I also think one or both of my rear tweeters are blown out as well.
What are my options for replacing it? I want something just drop in, I don't really want to wire up an amp and all of that at this time. I have a 12" kicker sub that i have waiting to go in, until I can afford the head unit i want.
But is there a good replacement sub out there I can put in for now? What about the tweeters?
Thanks,
Daniel
The problem is that the OEM amp doesn't put out enough power to run the aftermarket subs. If you just swap one in, performance will be worse than the original based on what I've seen. I put a JL sub in the stock enclosure and ran an amp, that's the best way to do it. Only other option is just unhooking the stock sub and wait until you get the 12" done, just do without the 8" sub.
I tried to look into a replacement OEM sub for you but what I found online was for the whole box/speaker (at least from the illustration) and it was over $220.
