Suspension Experts Needed
dr3ww3rd
I have searched for hours on end and I can't find what I'm looking for. I have a 2015 sr5 running 275/70/17 BFG KO2s and I would like a suspension setup that will raise the front about 2". I DO NOT WANT BILSTEIN 5100's. For my personal peace of mind I don't like the idea of the little C clips they use holding up my car. Anyway I have looked into the Old Man Emu front struts but can't find a spring to go with them to give me around a 2" lift. The car is a daily driver 95% of the time but I would still like to raise the front some. I also don't want to do a front spacer lift but understand I might have to run a rear spacer to bring the back up a little. I would greatly appreciate any advice people have as to the route I could go to achieve what I'm looking for. Pictures would be great if anyone has something similar to what I'm looking for. :frog:
If you do the calculations you would see that those "little c clips" have over a 10:1 DYNAMIC safety factor. Just sayin' because I have done the calculations lol.
For what its worth, I wheeled multiple times at Uwharrie(NC), Rausch Creek(PA), Windrock(TN), Hidden Falls(TX), & Shiloh Ridge(TX) and put 70K on a set of Billies on my Tacoma... Your fears are a bit overblown.
I agree.
I have close to 90k on my 5100's and they have seen some very rough roads. Moab, a bunch of passes around Ouray, CO, and all around Mt. Taylor and the Zuni mountains. They've taken more than a few rough hits that made me get out and make sure everything is still alright. Honestly, I'm more worried that my UCAs or balljoints will give out.
Plus there's guys like this ^^^ who calculates every detail that gives us piece of mind (or outright fear).
Those companies that make suspension items never test anything! I would never trust them!
:spy:
I can understand why everyone goes with the Bilstein suspension but I personally don't want to have to worry about it failing. There are plenty of people who have had that c clip fail. To each his own. I would just rather have welded perches
I thought the 884 gave 3" of lift. Is it worth upgrading to ome front struts or would you just stick with the factory struts?
It clearly says it gives 2" of lift, IF you want a full 3" to add a top plate spacer.
I'm going with Billies as soon as it's out of warranty. (and I can talk the wife into it) lol
I got 3" out of mine with no top spacers.
OP - maybe 883's or step up to coil overs.
I always thought the 884s were a 3" lift as well. if you go to the toytec website the complete OME kit says they provide a 3" but if you look at the springs by themselves it says 2". Is this because of difference in where the spring sits on the OME shock vs. stock shock?
I just ordered mine from Total Automotive and the site says 2.5"-3" lift. part number 2884. http://shop.totalautomotiveperformance.net/ome-old-man-emu/ome-coil-springs/2884/i-2018137.aspx
I am assuming that is the same as the 884 but I could be wrong.
For my personal peace of mind I don't like the idea of the little C clips they use holding up my car.....
The car is a daily driver 95% of the time but I would still like to raise the front some.....
Interesting remarks OP.
I've been reading this forum since 2010 and I cannot remember an instance of anyone reporting the failure of a Bilstein shock perch. It's such an easy, reliable, and cheap-ish way to improve ride/handling and gain some lift.
Lots of options for adjustable front coilovers. These are all adjustable from 0" to 2-3" of lift:
2010 - Current 4Runner Extended Travel Front Coilover Shock Kit - ICON Vehicle Dynamics
Toyota 4Runner 2015-2010 Front Shock - 2.0 Performance Series Coil-over IFP Coil-over Shock | FOX
BOSS Coilovers
Radflo Adjustable Front coilovers
The reason people go with 5100's is the cost/benefit ratio. They are a big improvement over stock without much extra cost. If you don't like the rings, don't want a spacer, and have the cash to spare, then go with one of the options above.
I just ordered mine from Total Automotive and the site says 2.5"-3" lift. part number 2884. OME Coil Springs - Total Automotive Performance - Your Source for Auto Parts and Accessories
Thanks for the order!!
OME has changed something small (Coating, color, etc) and now added a 2 in front of all of the parts numbers. 884 is now 2884. Spring size and rate has not changed.
The 2884 will provide the following, give or take .5"
05+ TACOMA:
Provides approximately 1″ lift on a stock Tacoma 4×4 with no Bull-Bar or Winch.
2003+ 4RUNNER:
Provides approximately 1-1.5″ lift on a 2003-2009 4Runner with no Bull-Bar or Winch.
Provides approximately 2.5-3″ lift on a 2010+ 4Runner with no Bull-Bar or Winch.
2007+ FJ CRUISER:
Provides approximately 2.25″ lift on a 2007-2009 FJ Cruiser with no Bull-Bar or Winch.
Provides approximately 2.75-3″ lift on a 2010+ FJ Cruiser with no Bull-Bar or Winch.
