Suspension Install - Just need confirmation....
jthoms1
Ok, I've stalked and read a ton of threads on suspension installs. I just need quick affirmation I am getting the right parts to accomplish what I want. I have a 2011 SR5 with 80k miles. So I'm going the route of replacing the shocks all around. I want a moderate lift and level. So, here's what I am planning on ordering.
1. Bilstein 5100's front adjustable
2. Bilstein 5100's rear
3. Sway-a-way coils w/1.5" lift
I'll set the front adjustable's to the 2.5" setting and install everything.
Do I have this right? Anything else I'll need (aside from time and tools)?
Thanks in advance.
Thanks in advance.
exactly the configuration I am running
I'm currently only running part of your configuration, but your configuration seems to be configured correctly for capable quality concurrency.
I just had the same set up installed on mine...small exception is I added the Toytec adjustable kit & coils in the front. I absolutely love the ride and the look. Best of luck with the install.
Hey you guys with the 5100's.... I have to ask because I like the OP am working on making my decisions and confirming pretty much exactly what he is, and I've been considering the 5160's and 6112's, still haven't figured out a rear coil that will accomplish a level lift at roughly 2-2.5 in front
But comparing 5100's and 5160's/6112's... is it worth the extra $$$? I'm basically trying to accomplish improved off road capabilities while retaining or improving on road manners and reliability.
