T-man's '05 Sport Build Thread
Well, the other rear bilstein bit the dust. Truck felt weird and I looked under at the axle and the passenger side shock has broke exactly like the drivers side did. Pulled right out of the threads... Stupid Bilsteins!
Dude, you over extended the shocks is my guess!!!
Sent from my SM-G920V using Tapatalk
They've been leaking for almost a year. My guess is it ran out of fluid and seized up like the other side.
But yes, I'm sure they've been over extended a ton! Lol
Sent from the drivers seat of my 05 4runner.
How many miles did you get out of them? Feel like they did their job well despite breaking now?
Build looks awesome, I spent way too much time at work reading this thread. However, now I have even more ideas :reddance:
I've hated them since month 4. To stiff, can't keep up at all, and although I have around 60k on them, I'll never buy another bilstein product. Blew a front out before too.
Thanks! I've spent many a day reading and getting ideas from others, then put my own twist on it. Lol
What are you planning on replacing the Bilsteins with?
Ok, settled on some rear shocks. Did a ton of researching, still can't afford Fox or Kings, so I'm going with these. http://www.lowrangeoffroad.com/doetsch-tech-shocks-8000.html they are 24.5" extended and 14.5" compressed, have a built in bumpstop, and are firm to control hard bumps and such, which is a leading cause of my Bilsteins failing and inability to keep up. I plan on adding superbumps after I get these installed and adding a spacer as needed to make sure the bumps stop at the stopping point of the shocks, or just before.
I wanted to get longer shocks, but can't until I can afford metal tech long travel coils. The 10" of travel on the ones I ordered should be more than sufficient for now.
I considered getting thier kit a while back, but ended up finding the takeoff Taco stuff - I ran d-tech on my lowered mini truck back in the late 90's, were great for lowered crowd and still are, they used to make some of the big name shocks like Toxic and rebrand - I think out of the small brands they had back in the day D-tech is the only ones taht are still around. The were good but somewhat soft on my application, I ended up trading them out for Koni's on the lowered application - the yllows of course as they were adjustable, but don't belive they do anything for the lifted crowd:)
Good luck, seems your very hard on parts and have the salty winters, the biggest complaint i found on the d-techs was the paint is crap, so if i was you would buy some very good clear - eastwood clear - something stronger than rustoleum and put a very good/thick coat on a few days before you install them. I think you would be good for years with them if you do that!
These are the 8000's, which are valved much firmer for prerunner applications, the 3000's are soft. I read many reviews and the only bad ones was that they are to firm, but every single review like that was guys using them on a Jeep Wrangler, which is shorter and much lighter. I'm not going with the kit specific to the 4runner either, I found the shock with 10" of travel, which is all I can use until I get longer coils. I'm hoping they will handle and hold up better than the Bilcraps!
Good looking on the paint! I will find some good epoxy paint for them and coat them a couple times before installing. See if I can find some red to go with my theme. :guitar2: Probably will look into some limit straps when I can as well since I'm sure that helped in the demise of the Billy's.
Got my new shocks! Massive compared to the bilstein. Painting then black and putting a couple coats of engine enamel clear over them.
And looking at this beast!
Define looking? Truck time in addition to 4runner?! Looks pretty sweet looks like a "contractor" truck and well that's what you do so...
Well, hopefully an addition, if financing plays nice... I need a bigger truck, and a truck with a bed too. I love my 4runner and it won't go unless there's just no other way. If I get the Tundra I'll be looking at building a rack like allpro sells,
But I would build it myself and make it even with the roof top, then build a rack over the top to hold ladders, sheets of sheathing/drywall, whatever comes up, as well as anything I'd like for offroading. I'd also get 17" rims and step down to 38-39" tires instead of the 40x15.5x20 setup it currently has. Lol
Here's my shocks painted and 2 coats of clear engine enamel on them.
Nice should hold up - and as for the 37's they are the best as you can still get them balanced at any tire shop, anything bigger - balls inside and bb's are only options.
Looks pretty nice, I think you would end up lowering it a bit espeically if you plan on using the rack to put ladders on...
Installed! Flexed it in neighbors yard... scratched them a little installing, sooooooo will have to do some touchups. Will give them a test over the next few days.
Ya, I have balance beads in my 35's. Worked good until tires went out of round. If I can keep both trucks will go with some all terrains on the Tundra, then swampers on the 4runner as it'll be an offroad toy at that point.
Installed my new O2 sensor today. According to Torque app it isn't stuck at .5v anymore, but it doesn't fluctuate as much as the passenger side, not even close. So not sure what's going on there, but hoping it doesn't pop a code anymore.
Supposed to get my new spindle/hub assembly for the drivers side tomorrow, and I have to order a wheel bearing for the passenger side too... Grrr. Lol
Next up when cash allows is brakes all around, resonators for the exhaust, wheels and tires as my rims are slightly bent and the tires are out of round. Thinking this is helping kill my wheel bearings. Also need to do timing belt, water pump, power steering pump, radiator since mine is full of dirt that I can't seem to get out, new hoses since I'm in there. Also thinking of switching to an electric fan. Any thoughts on that?
Other little things I can't think of right now too.
Other little things I can't think of right now too. [emoji106]
I'll be doing e-fan conversion fairly soon, wired up on thermostat with an override switch inside, do this on all my rides as we have a lot of water in Florida, not to mention my stock fan clutch is shot and it's loud sitting at idle everywhere. That's a lot of maint/mods coming up those always suck unless you do some upgrades st the same time! For the brakes make sure you do the 2010+ calipers and rotors when you do it, a little more bite and size for what typically is cheaper:)
I'll have to pick your brain on the wiring for the fan. Never done it before.
Thought about converting the brakes, but u already have the sport edition brakes, so it isn't an upgrade besides the potentially better calipers. Calipers would add drastically to the cost though... Ugh. Lol
I still want to sas as well...
