Tacoma Skid plate on an '03 4Runner.....(install pics)
Picture:
Re: Where did you get it?
Antoine said:
Looks really good! Do you know if they have that for the 2000 4runners?
I'm pretty sure they would have it for a 2000. If not you could get one and make some brackets yourself. That is what we had to do.
I got mine on ebay for about $60, i think. Since I knew I would be using the brackets that were coming with it, the model didn't matter.
If you are talking about the avatar pic, they are photochopped, but I am planning on mounting a set of Hella 500's there. I already have the lights but just need to make the brackets. If you open your hood and look down behind the front bumper, you will see two beams. I am going to mount the brackets to the beam, then run them out through the slots in the lower part of the bumper, then put the lights on them. I just need them to drop down slightly once they clear the bumper, to get the lights at the right height. I'll post some pics when I do it.
I was going to do the same thing. Actually, if you look at those beams, there are two holes pre-drilled straight through on each beam. I plan to use a bracket similar to the ones I used for the skid plates. I am not sure about having to drop it lower, because the plates are pretty thick, and bending them will be a challenge.
Prado Skid Plate
I know this is a Tacoma Skid Plate thread, but I posted a pic of this Prado (aka GX470) Skid Plate in another thread and I don't think many people even took a look at it. I love the look, but I think it is a little pricey, especially without knowing if it would work. Well, what do you'll think?
I had put a skid plate from the 02 4Runners on my 96 4Runner...now I have put it on my 05 4Runner...matches the silver GREAT! I will post pics of anyone is interested :)
Yeah I want to see pics! The pic you posted doesn't seem to show the skidplate.....or am I just missing it somehow? Edit: I adjusted the brightness of the pic and am now able to see it. Sorry, my monitor sucks.
honestly, with a westin safari bar, hood protector, license plate, my frontend is just seems really busy really busy.
with the bolts that i have now, the plate would line up slightly behind the the safari bar, and is as visible as everyones elses on here that has a skid plate without the safari bar.
Is either of these skid plate the right shape where it could be attached closer, or on, to the bumper? Basically, over the lower portion of the bumper. You know, the part that some 4runners have painted silver.
ian2328
