bob3dsf
I did mine with ignition on. The M/C pump will assist in the bleeding. On the rear brakes you can press and hold the brake pedal until clear fluid comes out. On the front you have to press-release-repeat. You'll hear the pump cycle as you press the pedal.
I did not use and toyota SST. Look up "one man-brake bleeder" as an alternative to speed bleeders There's a YT user named "Chris Fix" who has a good video as well as "Eric the Car Guy" if I remember correctly. An old jar of some type and some length of vinyl tubing from Lowes or HD. I THINK I had 1/4" ID but I'd have to double check. I just bought a few short diameters to test fit, then went and bought about 6' of the correct size.
I had problems with my speed bleeders (but many have had good experiences). A 1-man bottle makes it every bit as easy as speed bleeders. Just ensure the bottom of your bleeder hose remains immersed in fluid in the jar.
I don't think a vacuum bleed is necessary.
On 4th gens, the left/right order is not important, but I seem to remember the fronts are done 1st then the rears (look in the FSM).
Make sure your bleeder hose travels in an upward arc after the bleeder plug so any air bubbles can get trapped and not get back into your lines.
