Tech-Stream cable/OBD-ll protocols
Hi Team,
Okay, I think a got some of what's needed: Here's what happened in my effort to install/set-up the program...
I was able to use my old MINI-VCI j2534 OBD-ll cable and disc to load the firmware onto my WIN-10 64 laptop... total surprise (also, the drivers didn't install properly (according to a notification). But I still am encountering another problem... Here it's asking me for a LICENCE KEY (below)
This is the problem that I need to know what to do about; it's asking for a password below but I don't have one...
But I think there's a work-around because I'm having less trouble with this win-10 install/set-up than I was using my old win-7 w/virtual XP Mode app.
My Software vers. is "mvci-x64.reg" and "Techstream_Update _V8.10.
021.exe"
...is there a "Jail-break" procedure to resolve my faults with this set-up?
rig, thanks, and cheers!
The login page that you're at, is to access Toyota's servers. You need a subscription or have Toyota credentials to use it.
That's kind of what I was asking about in another thread. Will Techstream work without a subscription to TIS?
Yes, it will work fine. You can do diagnostics, change parameters, read live data, etc. You just won't be able to flash updates unless you get a subscription so you can download the calibration data. So you can do everything, for the most part, but without programming modules.
UPDATE: I had a bad install of Techstream. Uninstalled, restarted, installed fresh, restarted, and finally got all the features working.
Door lock/unlock chirps now OFF.
Seat Belt warnings OFF!!! HURRAY!
Can't turn off warning for key in ignition when door open, alas.
Oddly, can't seem to turn off rear window power-downs, only power-UPs.
