Short answer: smaller pulleys. The smaller the pulley, the more rotations of the rotors per crank of the engine, which means more compression/boost. I think he was running a 2.0 at one point. This would be overkill once again for the stock 2.38 pulley.
[MENTION=60928]lhsoulrebel[/MENTION] You've got it right, this is kind of the poor man's tune since we cannot tune our ECU's. What you will need is the meth injection kit as well as a wideband A/F ratio sensor and gauge in order to do it right though, if you just slap on a kit you'll have dead spots in your throttle. Also if you want it to be consistent, you will want to buy an injection kit with a progressive controller. This will allow you to gradually increase the flow as you add more throttle and boost. The sweet spot based of Speedy's and Gadget's research is about 12 AFR at 100% throttle. Some like to run a bit more rich, but anything higher that 12 will lose power.
From what I've read as far as reviews go and from members here on the forums I've asked (I am yet to buy one myself, currently putting in a new suspension) here is my very subjective list on what are the best kits to get from highest to lowest. They would all work just fine though.
1. Coolingmist - $549 (comes with gauge)
CMGS Stage 2 Progressive Methanol Water Injection
2. AEM - $462
Water/Methanol Injection Kit for Forced Induction Gasoline Engines | AEM
3. Snow Performance - $477
Snow Performance : Stage 2 Boost Cooler?
4. Devil's Own - $410
DVC-30 methanol Injection Kits : DevilsOwn water Injection
