The 3rd Gen All Questions Allowed Thread
Probably a vacuum issue. Either the vacuum hose for the vacuum canister/vsv is not connected to the correct spot (I did that the first time I did valve cover gaskets) or you have a problem with the vsv itself. I would check to see if you have vacuum at the front add actuator when you have the transfer case in 4wd.
OK great I will try this yes my hoses are a mess up in the engine bay
So I went to change my oil today, and when I was done, my hood decided to stop latching. After giving it multiple attempts at gently closing it, I began to drop it from about 1 to 2 feet and letting it slam shut. Still wouldn't latch. I even tried pressing on the hood with no luck. Thoughts?
I've tried adjusting those black rubber pieces already and that didn't have any effect on it. Here's a picture of the latching mechanism if that helps any.
Sent from my SM-S908U using Tapatalk
Pull the hood release lever inside the cab again
Sent from my Pixel 4 XL using Tapatalk
PB Blaster the whole mechanism. Spring and surfaces that slide/rotate on eachother. Take a flathead and push the flat hooky thing (inside the 'U'...not the big hood lever one) one way or another. Should spring back. Happens regularly on both of mine and seen it on multiple tacomas.
Hard to tell from the photo, but it may be latched already accidentally. I've done that a time or two leaning into the engine bay. Like octanejunkie said try pulling the release handle again. If not spray it down with lube of choice and try to move the mechanism with the blade of a screwdriver similar to how the hood catch would move it.
I changed out the old guage cluster bulbs for new leds, now the gas low light is always on, I still have over a quarter tank. Any ideas what happened and how I can fix it? I'm thinking unplug the connectors and reconnect them
Sent from my SM-A536U using Tapatalk
Put a halogen bulb back in it
Okay will try that for the gas light area
So the gas light went off but for some reason the right side dims after I put it all together but was full brightness when I first put the bulbs I thought I fixed the issue.. not sure but going to take the bulbs out again and swap em around.
The bulb holders are polarized, if you put one in "backwards" it won't light the bulb.
There are three main bulbs that illuminate the cluster face. You're lucky, the one on the far right when sitting in the truck is not under the circuit board. You don't need to fully remove the cluster to flip it (if you're careful)
Got it working great thank you! Next problem abs light picked up a abs control module and reset the code but the light is still on I know there's an abs fuse and possibly wiring that could have been chewed by rats. Any idea where I should start next?
What year is your truck?
1998 sr5
For 1998, I believe there's a 10 amp fuse in the cab for ABS - it's combined with cruise control system, anti-lock brake system, electronically controlled automatic transmission system, power antenna
It's number 25 in the diagram below
99 and up don't have this fuse in the cab
What’s the abs code?
AndiGarage
