Probably a vacuum issue. Either the vacuum hose for the vacuum canister/vsv is not connected to the correct spot (I did that the first time I did valve cover gaskets) or you have a problem with the vsv itself. I would check to see if you have vacuum at the front add actuator when you have the transfer case in 4wd.
OK great I will try this yes my hoses are a mess up in the engine bay
