Whatever scrap metal cost is for that weight so about 50 centsWhat is a dead OEM steering rack worth? I know some companies charge for cores so I feel like it has to be worth a couple bucks...
I was wondering what you guys thought a fair price was for a 236k 4Runner for parts would be? The engine has a oil light on and looks sludged but I need a frame and possibly a rear axle housing from it. He is wanting $1200 bucks is that fair?
Toyota 4Runner Wheel Specs: Lug Nut Torque, Hub Bore, Bolt Pattern & More | Sparky Express – Sparky Express Roadside Assistance
This chart, unless it is overly-simplified, makes me think I can use my (acorn style?) lug nuts putting 2020 TRD Offroad wheels on my 1999 Limited, and that everything else is the same. Anyone know definitively?
Has anyone on these forums ran the LC Engineering Valve Train upgrade for the 3.4L?
High Performance Pro Valve Train Kit 5VZ
any real benefits? Does this allow the motor to safely hit higher RPMs?
I had my radio antenna ripped off in a car wash, now every time I turn on or off the car the motor to raise the antenna (which is no longer there) runs for about 25 seconds. Is there a fuse I can pull to stop that from happening?
There isn't a fuse which is isolated to only controlling the antenna motor. The best thing I can think of is disconnecting the power cable which is one of the plugs on the back of the radio.
That sounds like a possible solution. I've also heard you can unplug the motor itself by going into the fender but there's a bunch of those black one-time-use clips to get through so I don't know if there's a trick to working with those or not.
I’m getting ready to replace my inner and outer tie rod ends. I know that the outer tie rod ends are different and specific to each side, but are the inner tie rod ends the same? Like i can just order two of the same inner tie rods and they can go on either side? Thanks to anyone that can answer this.
