crawlergrunt3187
Hello all. I have a 2000 4Runner SR5 with a diamond axle and an LC 3rd member reverse high pinion up front, Detroit locker, manual hub, tundra brake. So up front is pretty solid. Running a Marlin dual case. 4.88 re-geared and on 37’s, method bead grips, Tom woods driveshafts. Rear is stock 8 axle with All pro leaf spring conversion and ballistic fan shackles, diff breather mod, actuator skid, bash plate from low range welded on. My question is: if you had money to blow for about a thousand, what mod would you do to this? Disc brake conversion? Trying to beef this as much as possible before I hit Rubicon Trail next month.
