The 3rd Gen All Questions Allowed Thread
Hi all, my steering rack boot has been ripped for some time and it finally has started leaking and I’ve noticed a lot more play in my steering. The boot is just leaking out grease so my seals are likely still ok but I need to investigate the steering play and replace the boot itself. However I am moving back to college this week and have a 16+ hour drive. Wondering if anyone has thoughts on if this is something I should deal with before or if I can deal with it at college?
I would also love an info/videos on how to find which steering component has play and needs to be replaced.
There's basically no grease in the steering boot. If something is coming out, it is from the rack. A ripped boot lets in contaminants, but isn't the end of the world unless you are going to go the whole winter in the salt belt with it open.
For play in the steering - you'll need a helper and maybe some ramps. Key on, engine off. One person wiggles the steering wheel back and forth, the other feels every joint from the hub back up to the steering wheel for play. See what you get... the only one that is hard to feel with that method is inner tie rods.
-Charlie
Hey, everyone I got a 97 Toyota, 4 runner, 2 wheel drive auto and randomly.It will act like it's trying to find a position in between 2 gears or just bogs down completely while driving.I put it in neutral, slapped the throttle.And it's fine , but when it's in gear , it does not want to give any throttle it doesn't happen all the time.It only happens occasionally.Does anyone here have any guess?I bought a cheap t.P.s and it idled high , I just put the old one back on , and it's fine now I know that I haven't air control valve problem Any guesses
Any codes?
Due to the site sustaining permissions issues for threads with 100+ pages, I'm starting this new thread for you guys. I can merge the threads together at some point, if the issue every gets fixed.
Enjoy
:llama:
The issue seem to be resolved with the new software these topics can now be merged together?
Sorry if this has already been asked but I can't find much info on the forums or online about this.
Has anyone ever taken fender flares and the door cladding from the Limited trim and retrofit it onto their base or Sr5?
I love my 4Runner and I've put a lot of work into it so far but I really wish it was a widebody truck.
PFA
I recently cut out my old rusted exhaust from the merge collector just before the upstream O2 sensor, welded in a stainless 2-1/4" v-band and rebuilt the exhaust out of 2-1/4" 304L with a magna flow universal cat and a borla pro XS muffler. The fit is fine, the issue i'm having is I welded in two M18 O2 bungs (both upstream and down stream, not flange compatible) and now finding O2 sensors that are compatible with the 3.4 5VZ that do not have the factory mounting flange is difficult. I've tried removing the flange from the threads of the denso 234-4161 and an aftermarket universal walker, but I end up damaging the ceramic portion of the sensor in the process.
Anyone run into this issue before, or know of a threaded O2 sensor that will play nicely with the ECU for the 5VZ? Thank you for any and all help!
O2 sensor specific change with year, emissions package and transmission package (and 2WD/4WD). Mostly for wire length, but also type (AFR vs. O2). You'll need to get specific. I would suggest getting a new Denso or NTK sensor for your application from RockAuto (or other trusted retailer), which will come with a standard threaded O2 sensor and the adapter separate for easy install with your special setup.
-Charlie
-Charlie
Thank you for taking the time to respond. It's a '97 5-spd with the standard narrow band, 4-wire O2's for both upstream and down. I've been having trouble finding a sensor with appropriate wire length and connector, but without the flange pre-assembled and was hoping someone had crossed this bridge before.
Top is your downstream 234-4154. Wire length is 12.91 . Below that is the rear sensor for the '01-'02 5VZs. These are standard O2s and are threaded P/N 234-4261. Wire length is 10.24" Fronts are A/F so they won't work at all. Rear plug looks like a match, but wire is too short, The upstream for yours is 234-4161. Identical but wire length is 15.35 inch. So the 234-4361 is too short there, too. So I suggest you purchase two 234-4209 which are universal threaded O2 which come with a 11.77" pigtail and no plug but otherwise identical to the 234-4261. . Then you splice those on to your existing plugs leaving just the amount of wire you need. I haven't tried it but I'm pretty sure it will work fine. I'm just not sure if the thread is the same as what you stuck on your rig.
Linky 234-4209
Thanks for the in-depth part number suggestions, sounds like the universal 234-4209 will be my best bet. Funnily enough, I came across a post of yours from 2011 thread talking about essentially the same thing. Kind of hate when my searches only turn up the info I don't need, but the 4209 part number pulled that archived post up immediately. Anyhow, thank you again for your time. I'll let you know the results.
Hey guys, been searching the forums for a bit for a tube front bumper, leaning HEAVY towards the trail gear bumper, I saw some builds with it but the threads are older and the links to the bumper are no longer valid. Is the correct bumper that will slide on the frame, the 95-04 taco bumper? I just want to make sure before I pull the trigger on this. Thanks in advance. Here’s the current link to the 95-04 bumper https://trail-gear.com/armor/rock-defense-front-tacoma-bumper-95-04.html
You could just contact the guys at TG directly and ask them. They're pretty helpful.
My 4runner started getting hard to start. It's just a ranch vehicle so it doesn't get ran often. Then it failed to start. I recently replaced the fuel pump. All was good. Then about a month later it won't start again. Fuel pump is turning on when key is first turned. I don't think it's a fuel pump issue. I'm getting spark. At least on the two plugs I pulled. I replaced the coolant temp sensor. I know those can cause flooding. But no change. I did hit the key while I had the fuel rails apart and fuel sprayed everywhere. Would cam angle sensor failure prevent spark. That's my next guess or crank angle sensor. Last few time it was running it was super rough. I would have to press gas pedal to keep it going. Then, after a couple of minutes it would just suddenly line out and idle perfect.
tobasko556
