The Best Mobil Synthetic 75w90 gear oil. Share my bulk purchase & save $ -Northern VA
pjbrownva
Mobil Delvac is **BETTER** than Mobil 1 (Don't believe me... believe Mobil... info below)
Use it in front and rear differentials, plus the transfer case.
I'm selling as much as you need -- up to 3.5 Gals -- **at cost** which is $40 per Gal.
1 Gallon of Mobil Delvac sells for $65 plus shipping, but a 5 Gal Pail of Delvac costs $200 which works out to only $40 per gallon.
I needed 1.5 gals, so rather than spending $130 + shipping for 2 Gals, I figured I'd spend $200 for 5 Gals, and sell at cost whatever I don't use. This way I can have the very best gear oil in my front & rear diffs and transfer case, while saving money....
and others can too!
We all save, so we all win!!!!
Get Mobil's best synthetic gear oil while saving money too!
This is the really good stuff that includes "protection against the combination of thermal degradation, component wear, and oil seal deterioration which is not provided by lubricants meeting only the requirements of API GL-4 and API GL-5."
Delvac is Mobil's commercial (rather than consumer) grade of synthetic oil.
Mobil Delvac is a GL-5 rated synthetic oil (like Mobil 1), that is better than the regular Mobil 1 gear oil you see on the shelf at the store, because Mobil Delvac is enhanced to *also* meet MT-1 specs, which means that it has extra wear protection, better resistance to thermal breakdown, more resistance to high-torque sheer, and it contains seal conditioners too. !!!
Don't believe me... believe Mobil !!!
More info and photos are below.
-Phil
Phil at pjb3 com
Use this to get improved performance and longer oil life with better protection.
Don't risk premature wear from thermal breakdown of the regular Mobil 1 oil!
4th & 5th Gens require GL-5 oil, and THIS oil is also MT-1 rated, while the regular
Mobil 1 gear oil isn't.
Here's a description of the GL-4, GL-5 & MT-1 ratings.
API Category GL-4 designates the type of service characteristic of spiral-bevel and hypoid gears in automotive axles operated under moderate speeds and loads. These oils may be used in selected manual transmission and transaxle applications
API Category GL-5 designates the type of service characteristic of gears, particularly hypoids in automotive axles under high-speed and/or low-speed, high-torque conditions. Lubricants qualified under U.S. Military specification MIL-L-2105D (formerly MIL-L-2015C), MIL-PRF-2105E and SAE J2360 satisfy the requirements of the API GL-5 service designation.
API Category MT-1 designates lubricants intended for non-synchronized manual transmissions used in buses and heavy-duty trucks. Lubricants meeting API MT-1 provide protection against the combination of thermal degradation, component wear, and oil seal deterioration which is not provided by lubricants meeting only the requirements of API GL-4 and API GL-5.
This Mobil Delvac oil is GL-5 / MT-1 rated, so it has better protection against thermal degradation and component wear!!!
Local pickup strongly preferred, to avoid shipping costs for the buyers..., but if you really want it shipped, I'll consider it. Shipping will be actual cost.
I'm located in Arlington, VA.
Phil at pjb3 com.
Seven Oh 3, Sixx 3 7, Niner 1 Fiver 2. (cell)
(email, call or text -- Spelled funny to keep bots away).
(There is no markup on this. I'm just doing it so we can all get the very best
Mobil Synthetic, and save some money in the process.)
(Here's the Mobil Oil Delvac site for more info)
I'll be through that area in OCTOBER and will take some if you still have it, but don't save it for me if you can sell it sooner.
That sounds good. Email me when it gets closer, and I'll let you know.
Phil at pjb3 com.
If no one comes forward I might post on other forums (like for Tacomas and F150s), and also use some as gear oil for the lower unit in my boat.
