The Big Question
4OYOTER
275/70R17 with 1.75" Billy's on the front with no touch on the rear...
OR
285/70R17 with a full set of Billies at 2.5" on OEM coils. and 1.5" Daystar coil spacer in the rear.
Obviously budget is a big factor. Not a lot of offroad, but overall reliability and capability is important.
Been discussed many many times so you might get some snippy answers. The first set up will look slightly level, to almost having a reverse rake. You could always add a small spacer in the rear if that is the case. The second setup is fine, you may need to do some fender trimming or pushing back of the liners. I would also recommend doing Bilstein shocks in the rear on either setup if you didn't plan that already, to keep the ride the same. In your second setup you may want to swap out the Daystars for some SAW springs, for a 1.5 inch lift with no spacer. Good luck!
"....NO we're NOT going to do fugggin STONE-HENDGE!!!!!"
sorry, i'm a TK little, which made it an easy come-back ...
If budget is a big factor, I feel like option one is your only choice.
Just the tires on option 2 will cost more than the entirety of option 1.
delislerebecca
