The Fourplayer Build
Daron-t4r
Hey there, decided it would be fun to write about my on-going build of the 4runner, so here it is.
Right Now
IMG_1109-1.jpg~original
DSC00120-1.jpg~original
Day I bought it
IMG_0227.jpg~original
Mods
Suspension
Front Toytec Adjustable Coilovers RED
Rear Bilstein 5100s
Rear Toytec Superflex
Tires/Wheels
17" Black Plasti-Dip Limited Wheels with Silver Chrome hub caps
Goodyear Duratrac LT285/70/17
All-pro 1.5" spacers
Offroad
Custom Skid plates
Outfitting/Electronics
Uniden pro520XL CB radio and PA speaker -- 4' whip antenna
Underdog Racing Development MAF calibrator
aFe Stage II SI Cold Air Intake
Cutom VSC-off mod
Weather-tech Hood Protector
Integrated Radar Detector
Husky All-Weather Floor mats
TRD-chrome grill badge
30 HP worth of stickers...
To come-In order
Aftermarket front bumper -Demello
Winch- t-maxx 9.5e
Sliders- Demello
Wheels- undecided
On-board air compressor- viair
ARB Rear air locker
More Pics
DSC00122.jpg~original
DSC00054.jpg~original
IMG_0708.jpg~original
DSC00123.jpg~original
DSC00062.jpg~original
IMG_0730.jpg~original
img1055js.jpg~original
Looks good!! any pics with the 285's and All-pro spacers installed?
Also curious about the custom skid plates you have listed.
Thanks Darkie! Your build is an inspiration for mine. Pics with the all pros and the 285s coming soon, Either tomorrow or the next day, I didn't get the right amount of extended lugs from all pro for some reason, whether it was my mistake or theirs, so depending on when I get those, I'll have the pics up as soon as possible!
Also, for the skids, my buddy works at a fab shop, and with some left over metal from another project of his, we fashioned a front, and middle skid. We're still ironing out the kinks in the skid, because we had a few problems the first time we put them on, so they arn't on at the present, but they are coming in the near future as well.
Just thought I'd add a few things I have done to get where I am. Still anxiously awaiting the 285 and spacer installation!!
First Plasti-Dip experience:
I practiced on the spare first, I used playing cards to line the edges of the wheel while I sprayed (not mandatory)
scaled.php
Next I did 4 coats. 1) think coat 2-4) medium spray over coats going from different directions. Heres the finished product. I didn't do the hub caps.
scaled.php
IMG_0707.jpg~original
Ended up using 2 cans, and I probably could have gone with another 1-2 coats, but it has held up mostly so far, and I'm pleased with the outcome. I also did a buddy's jeep for 100$, and I did 7 coats on that... it has had NO flaking or tearing as of yet.
URD Maf cal
Next thing of note that I did was the URD MAF cal install. With my mediocre knowledge of wire tapping/soldering, and the good diagram provided by gadget, it was a smooth install. Thanks go out to Gaterose aswell, who sold me the unit. (full build thread:http://www.toyota-4runner.org/4th-gen-t4rs/104217-urd-maf-cal.html)
First I took off the glove compartment, and found the 5 plugs on the far right which were the ones we needed to mess with, I labeled them A-F so as not to accidentally mess them up
Then I stripped them back and and wound the correct wire from the URD PCU around the ECU wire.
Then I soldered the wires together, and used liquid tape and wire caps
I found a place I could put the PCU, and stuck it there with industrial Velcro, after some serious offroading, its still seriously stuck in place.
Next, the Toytec Ultimate LIFT! I set out doing this lift with little experience, but boy am I glad I did it myself, Its great to know everything about your car, and I'll tell you, I know a hell of alot about 4runner suspensions now. (also tip from experience, don't unscrew the bolt on the shocks that connect to the XREAS, just saying)
I started outside, with the front because it is the most time consuming, and jacked up the car, removed the wheels, and placed jackstands under the frame.
IMG_6410.jpg~original
Comparison of the front coilover I removed, and the toytec one
IMG_1006.jpg~original
Coilover finally installed on both sides, after the impact wrench broke, and the torque wrench.
IMG_1005.jpg~original
Sway bar relocate
IMG_1004.jpg~original
With tires back on
IMG_1013.jpg~original
Replacement rear coil (superflex)
IMG_1010.jpg~original
Had to do some banding to reach the nut on the top of the rear shock
IMG_1012.jpg~original
Tebowing after overtime win
IMG_1007.jpg~original
Now shes lifted
Totally forgot to update this thread when I put my new tires and spacers on. So here it is, I'll snap a few cleaner pics tomorrow as well.
IMG_1094.jpg~original
IMG_1110.jpg~original
IMG_1107.jpg~original
