The Last LED Bulbs to go in the 4Runner - Lasfit Turnsignals
007Tacoma
Of all the bulbs we have replaced in the 4Runner, the last ones to get upgraded to LED are the Turn Signals in the front and rear. In the video below, we go over the install and compare them to the OEM Turn Signals as well as show what these look like going down the road.
Cheers!
I installed LASFITs in the front and rear turn signals and they are great. Almost too bright at night, but other drivers are sure to notice you.
The front installation is just a little tricky. You have to undo some clips on the wheel well plastic and reach your arm way up. Wear long sleeves. The details of how to do this are in your 4R owner manual.
Me: Hmm, a 5 min vid for signal bulbs.
the vid: "for this we are going to have to take off the entire bumper"...
I've got these in front and back. Love how bright they are.... I can even see the amber reflection hit certain road signs in the middle of the afternoon!
Yeah... I realized after I did all this that I could have just reached up behind the fender liner, but its still a pain in the butt.
no need for resistors (or a new electronic flasher relay) with these turn signal bulbs? no hyperflash?
There are resistors built into these bulbs so they look like incandescents to the dumb flasher and there’s no hyperflash. LASFIT erroneously calls them “Canbus”. Since these bulbs are driven so hard to get them so bright they will get hot with extended use, like 10 minutes or so on a hot summer day. There’s also some type of built-in thermal switch that opens up to protect the resistors in this case (they are physically small and can only dissipate so much heat even with aluminum heat sinking). When that happens you will hyperflash but when turning off the blinkers for a short time, maybe 30 seconds, the switch resets and all is well. I’ve had mine over a year and the only time I could get them to hyperflash was by leaving the emergency flashers on for about 20 minutes.
My alpharex headlights just came in, but will wait to install. I gotta get these first! Excellent DIY thank you!!!
That is correct. The bulbs are the only thing you need.
Yeah, it really irritates me when any manufacturer or marketer says bulbs are "CANBUS".
It would better to say they are "compatible with most CANBUS monitored circuits since they mimic the load of an incandescent bulb"... but that's a lot of words most people probably won't read or understand.
I know I feel like I am... but I've also cut mine up so many times for different things that I probably should buy a new one at this point.
:lookout:
Ha, I am due for a new one but every time a new scratch happens I say "glad I didn't have a new bumper" :tea:
When (if) they update the front end I'll buy one
....I’ve had mine over a year and the only time I could get them to hyperflash was by leaving the emergency flashers on for about 20 minutes.
I find this irritating with mine. In fact, it looks like an emergency vehicle on the road when they don't flash in sync. But whatever, not a big deal to me.
Been runnning these in rear rear turn signals for 1-1/2 years now. They work fine and cost about half the price of Lasfit.
OXILAM 7440 LED Bulbs Amber Yellow 2800LM for Turn Signal Lights with Build-in Load Resistor CANBUS Error Free T20 7440NA 7441 W21W WY21W Blinker Bulb Replacement (2PCS)
by OXILAM
Amazon.com: OXILAM 7440 LED Bulbs Amber Yellow 2800LM for Turn Signal Lights with Build-in Load Resistor CANBUS Error Free T20 7440NA 7441 W21W WY21W Blinker Bulb Replacement (2PCS): Automotive
Adding this to the list of subtle mods that make the vehicle look better and perform better (Safety in this case). I'll be coming back here when its time. Just need a good reason to pull the bumper, because as of right now, this isn't it just by itself.
Well... I messed up in the video. Turns out you don't have to pull the bumper. You can access these bulbs via the wheel well liner. It wouldn't have made an interesting video, but it would have been a ton easier.
On the bright side you didn't scratch your arms up reaching in there.
chasebradshaw
