The Official 3rd Gen Dual Case, Dual Locked Thread
Just a suggestion: How about changing it to just dual cased 3rd gens? Anyone can throw 35's and a front locker in, but dual cases is a much more involved mod. I can see a lot of value in having all of the dual cased rigs compiled in one thread, lockers and 35's or not.
That's a good Idea. I will pm a mod and see about changing the title and then I will update the first post to reflect that.
I am a huge fan of marlin's stuff but Trail-Gear has come a long way and that is who I used because marlin was out of stock. The quality is great. Get either that is in stock and who has a sale. Hard to go wrong either way. Oh and also inchworm is high quality also
Which Trail-Gear kit did you use?
I have all the parts already (DUMC + Marlin's adapter to the 3.4L)....but I'm waiting to install it until I'm ready to cut the IFS out and put in the FJ80 front axle.
Still have to widen the FJ80 axle 4", finish the rear housing work and add disc brakes, build/plumb a cell and skid under the rear cargo area and sleeve/plate the center frame section for the link basket before I cut off the IFS.
I may rework the rear tire carrier and shorten the sliders before cut the IFS too..... Lots of work.
I used the Taco adapter (orange one) and then the adapter that mates the gear reduction box to the stock T-Case. The one thing to remember is that you have to change out the reduction box gear from 21 spline to 23. I spent the day wheeling today (yes on a tuesday. woo hoo) and the cases just worked flawlessly.
I've GOT to research this. Not only is it wicked-cool; but if it allows retention of 4.10s (I have a 5spd) for highway use while giving a crawl option like my M715... sounds like the best of both worlds; what am I missing?
Nothing. It is the best money you can spend in terms of capability beyond lockers.
Couldn't agree more but I might argue that (even though I didn't do it in this order) dual cases before lockers can take you a long way. Get both and you will never look back. hehe
I might actually agree....one locker and a crawl box is probably more useful than just 2 lockers. I still think at least one locker is the best buy in terms of making a T4R capable offroad.
Well, I have a locker on the bench, so... ;)
Where can I educate myself on this further? ($$)
Inchworm Gear Products from Low Range Off-Road | Dual Transfer Case | Tacoma Adapters | Lefty
https://www.marlincrawler.com/transfer-case/line-ups
https://www.marlincrawler.com/transfer-case/line-ups/gears
www.trailgear.com
It can get pretty confusing.....you have a chain drive tcase which is weaker than the older gear driven style. You *can* convert to gear driven.....but if you want to keep your current IFS or use a driver drop solid front axle, you'll need the "lefty" from Inchworm. You can add a second, gear driven case in front of your chain driven case as well to keep driver drop. Also, in the gear driven cases, you can buy 4.7:1 gears....factory low range is 2.28 in the gear driven cases.
IMO, Marlin's parts are the highest quality....but customer service has severely slipped since he stopped dealing with customers directly.
All of the designs now are very similar though....to be fair.
OK, so if want to retain both the IFS and my stock transfer case, what am I looking at? An adapter and a 1/2 of a junkyard tacoma transfer case?
(besides the obvious: driveshaft modifications, remote sticks, additional crossmember or crossmember relocation?)
you will need two adapter plates, 1 taco plate and one for the dual adapter. then you will need a reduction box from an early (pre tacoma) 4cyl pickup or 4runner. preferably 1985-1988. Then you will need a new input shaft gear to convert reduction box to 23 spline. You have the choice of stock 2.3:1 or 4.7:1 gear ratio. Then follow the directions and put it all together. One other thing to consider is to put a new set of bearings in the reduction box as the ones that are in the used box are at least 28 years old and might be a little worn. Then yes you will need front and rear drive shafts as well as some electrical extensions for the plugs that are on the stock tcase. It seems like a lot but totally worth it.
OK, so grab the reduction box from a first gen 22RE IFS 4runner, check.
Let me ask: did you have to do crossmember work to install? who modified your driveshafts?
I suppose you can add me to the list
1997 SR5
3.4 Turbocharged
5 Speed
Marlin Tacobox with 4.7 reduction
4.88 Revolution gears
ARB front and E-locker rear
315/75/16 Cooper STT Pro's
if you have a manual trans you can get away for a little while without modifying the crossmember but you will want to build something more stout eventually if you have an automatic you will need to do a crossmember right away. Drive shafts I had rebuilt at a local drive shaft shop here in town.
You don't need CAD....just a measuring tape. ;)
exactly :) once it is all installed measure flange to flange from the tcase to the axle. take your drive shafts to a shop with those measurements and pick them up a couple of days later, and install then drive really slow.
LOL, I'd rather have the shafts made while I'm doing the conversion/install for less downtime (my daily)
what is the additional length of the reduction box+adapters?
2001ATL
