The SkylineGTRracer's 2006 build
me too, but i think the ones to the calipers are the most important ones right? the ones on the axel i have seen are longer than stock lines, do you think if you get the front lines again, would it fit there?
If lowered yes, however I think some off road shops have extended length stainless lines for that particular set of lines. I wouldn't want to induce stress of the stainless lines due to the movement and articulation of the axle because they were too short. I'd like to think in this area that your only as strong as your weakest leak, hence, that set of rubber lines. So following that logic I would want to upgrade since I push my truck hard on the track.
I felt that I needed a little show with the go so I painted my valve covers. I had wanted to have them blue but I felt it might not have gone well with silver. I narrowed it down to red and I wanted a finish similar to what ferrari does, a textured finish. One can of wrinkle red and a days worth of prep and painting and it seems like the end result came out well.
Great build! I want to check out one of those custom intake manifolds.
I really want to find a set of the NST pulleys. If you find a set, please let me know! I want to start tuning my truck a little bit
Cleaning up the gallery section in preparation to clean up/delete some subforums. Moved your build to the 4th gen section with the others.
Those wheels look amazing on your ride dude!! Any plans for lowering it in the future?
Not really, I like the stock height. If anything I'll lower the rear to match the front.
The wheels look great dude!!
Those wheels look awesome!
Thanks ya'll!
That looks incredible!
Coming to Texas in October. I wanna check out your truck really bad. Need to tune
Sure, come on by.
He actually has the FJ coils and springs I believe. He's taller
I'm running stock springs with TRD FJ shocks.
At least I knew your suspension was FJ related haha
Wish we could go to a track or something.... I wanna see this thing move!
well I'm back from tx2k with some new goodies. Bought an AEM AFR gauge on the cheap.
Also bought a 'coupe' TRD battery tie down. It has a very nice wrinkle finish with top grade components.
I have also found a shop that can import my kelford cams so an engine build in in the near future.
I can hang well in this group.
Also this might be my next car in a few months.
Makes over 700 whp on hennessy's crappy dyno.
